X-014
I put a 20" X 36", 2 by 4 inch mesh reflector 4 inches behind the X-011 and got a little bit more gain out of the design. 13 dbi versus 12 dbi (or less for the same frequency) for the Fracarro P54.
For a 12 dbi antenna, it has a very wide beamwidth. This 3D beamwidth pattern is at 585mhz, channel 33, the middle of the new UHF band. It also appears to be a fairly forgiving design, spacing-wise. This could be a very cheap and easy antenna to build using electric fence stand-offs that are made for chain link fences. (available at Tractor Supply)
And the NEC file :
CM Experimental Antenna
CM Italian Four Diamond Antenna Design X-014
CM AWG Gauge 6 Copper Wire elements, 2 by 4 inch mesh reflector
CM Reflector to Driven Element distance - 4.0 inches
CE
GW 1 1 0 -0.4188583 0 0 0.41885827 0 0.089
GW 2 11 0 0.41885827 0 0 4.84110236 4.84110236 0.081
GW 3 11 0 4.84110236 4.84110236 -0.1968504 0 9.68220472 0.081
GW 4 7 -0.1968504 0 9.68220472 0 -2.9209055 12.6031102 0.081
GW 5 7 0 -2.9209055 12.6031102 0 0 15.5240157 0.081
GW 6 11 0 -0.4188583 0 0 -4.8411024 4.84110236 0.081
GW 7 11 0 -4.8411024 4.84110236 0.19685039 0 9.68220472 0.081
GW 8 7 0.19685039 0 9.68220472 0 2.92090551 12.6031102 0.081
GW 9 7 0 2.92090551 12.6031102 0 0 15.5240157 0.081
GW 10 11 0 0.41885827 0 0 4.84110236 -4.8411024 0.081
GW 11 11 0 4.84110236 -4.8411024 0.19685039 0 -9.6822047 0.081
GW 12 7 0.19685039 0 -9.6822047 0 -2.9209055 -12.60311 0.081
GW 13 7 0 -2.9209055 -12.60311 0 0 -15.524016 0.081
GW 14 11 0 -0.4188583 0 0 -4.8411024 -4.8411024 0.081
GW 15 11 0 -4.8411024 -4.8411024 -0.1968504 0 -9.6822047 0.081
GW 16 7 -0.1968504 0 -9.6822047 0 2.92090551 -12.60311 0.081
GW 17 7 0 2.92090551 -12.60311 0 0 -15.524016 0.081
GW 139 3 -4 -10 18 -4 -10 16 0.050949
GW 140 3 -4 -10 16 -4 -10 14 0.050949
GW 141 3 -4 -10 14 -4 -10 12 0.050949
GW 142 3 -4 -10 12 -4 -10 10 0.050949
GW 143 3 -4 -10 10 -4 -10 8 0.050949
GW 144 3 -4 -10 8 -4 -10 6 0.050949
GW 145 3 -4 -10 6 -4 -10 4 0.050949
GW 146 3 -4 -10 4 -4 -10 2 0.050949
GW 147 3 -4 -10 2 -4 -10 0 0.050949
GW 148 3 -4 -10 0 -4 -10 -2 0.050949
GW 149 3 -4 -10 -2 -4 -10 -4 0.050949
GW 150 3 -4 -10 -4 -4 -10 -6 0.050949
GW 151 3 -4 -10 -6 -4 -10 -8 0.050949
GW 152 3 -4 -10 -8 -4 -10 -10 0.050949
GW 153 3 -4 -10 -10 -4 -10 -12 0.050949
GW 154 3 -4 -10 -12 -4 -10 -14 0.050949
GW 155 3 -4 -10 -14 -4 -10 -16 0.050949
GW 157 3 -4 -6 18 -4 -6 16 0.050949
GW 158 3 -4 -6 16 -4 -6 14 0.050949
GW 159 3 -4 -6 14 -4 -6 12 0.050949
GW 160 3 -4 -6 12 -4 -6 10 0.050949
GW 161 3 -4 -6 10 -4 -6 8 0.050949
GW 162 3 -4 -6 8 -4 -6 6 0.050949
GW 163 3 -4 -6 6 -4 -6 4 0.050949
GW 164 3 -4 -6 4 -4 -6 2 0.050949
GW 165 3 -4 -6 2 -4 -6 0 0.050949
GW 166 3 -4 -6 0 -4 -6 -2 0.050949
GW 167 3 -4 -6 -2 -4 -6 -4 0.050949
GW 168 3 -4 -6 -4 -4 -6 -6 0.050949
GW 169 3 -4 -6 -6 -4 -6 -8 0.050949
GW 170 3 -4 -6 -8 -4 -6 -10 0.050949
GW 171 3 -4 -6 -10 -4 -6 -12 0.050949
GW 172 3 -4 -6 -12 -4 -6 -14 0.050949
GW 173 3 -4 -6 -14 -4 -6 -16 0.050949
GW 174 3 -4 -6 -16 -4 -6 -18 0.050949
GW 176 3 -4 -2 18 -4 -2 16 0.050949
GW 177 3 -4 -2 16 -4 -2 14 0.050949
GW 178 3 -4 -2 14 -4 -2 12 0.050949
GW 179 3 -4 -2 8 -4 -2 6 0.050949
GW 180 3 -4 -2 6 -4 -2 4 0.050949
GW 181 3 -4 -2 4 -4 -2 2 0.050949
GW 182 3 -4 -2 2 -4 -2 0 0.050949
GW 183 3 -4 -2 0 -4 -2 -2 0.050949
GW 184 3 -4 -2 -2 -4 -2 -4 0.050949
GW 185 3 -4 -2 -4 -4 -2 -6 0.050949
GW 186 3 -4 -2 -6 -4 -2 -8 0.050949
GW 187 3 -4 -2 -8 -4 -2 -10 0.050949
GW 188 3 -4 -2 -10 -4 -2 -12 0.050949
GW 189 3 -4 -2 -12 -4 -2 -14 0.050949
GW 190 3 -4 -2 -14 -4 -2 -16 0.050949
GW 191 3 -4 -2 -16 -4 -2 -18 0.050949
GW 194 3 -4 -10 -16 -4 -10 -18 0.050949
GW 196 3 -4 -2 12 -4 -2 10 0.050949
GW 197 3 -4 -2 8 -4 -2 10 0.050949
GW 201 7 -4 -2 18 -4 -6 18 0.050949
GW 202 7 -4 -6 18 -4 -10 18 0.050949
GW 206 7 -4 -2 16 -4 -6 16 0.050949
GW 207 7 -4 -6 16 -4 -10 16 0.050949
GW 209 7 -4 -2 14 -4 -6 14 0.050949
GW 210 7 -4 -6 14 -4 -10 14 0.050949
GW 215 7 -4 -2 -18 -4 -6 -18 0.050949
GW 216 7 -4 -6 -18 -4 -10 -18 0.050949
GW 218 7 -4 -2 -16 -4 -6 -16 0.050949
GW 219 7 -4 -6 -16 -4 -10 -16 0.050949
GW 221 7 -4 -2 -14 -4 -6 -14 0.050949
GW 222 7 -4 -6 -14 -4 -10 -14 0.050949
GW 224 7 -4 -2 8 -4 -6 8 0.050949
GW 225 7 -4 -6 8 -4 -10 8 0.050949
GW 227 7 -4 -2 6 -4 -6 6 0.050949
GW 228 7 -4 -6 6 -4 -10 6 0.050949
GW 230 7 -4 -2 4 -4 -6 4 0.050949
GW 231 7 -4 -6 4 -4 -10 4 0.050949
GW 233 7 -4 -2 2 -4 -6 2 0.050949
GW 234 7 -4 -6 2 -4 -10 2 0.050949
GW 236 7 -4 -2 -2 -4 -6 -2 0.050949
GW 237 7 -4 -6 -2 -4 -10 -2 0.050949
GW 239 7 -4 -2 0 -4 -6 0 0.050949
GW 240 7 -4 -6 0 -4 -10 0 0.050949
GW 242 7 -4 -2 -4 -4 -6 -4 0.050949
GW 243 7 -4 -6 -4 -4 -10 -4 0.050949
GW 245 7 -4 -2 -6 -4 -6 -6 0.050949
GW 246 7 -4 -6 -6 -4 -10 -6 0.050949
GW 248 7 -4 -2 -8 -4 -6 -8 0.050949
GW 249 7 -4 -6 -8 -4 -10 -8 0.050949
GW 251 7 -4 -2 -10 -4 -6 -10 0.050949
GW 252 7 -4 -6 -10 -4 -10 -10 0.050949
GW 254 7 -4 -2 -12 -4 -6 -12 0.050949
GW 255 7 -4 -6 -12 -4 -10 -12 0.050949
GW 257 7 -4 -2 12 -4 -6 12 0.050949
GW 258 7 -4 -6 12 -4 -10 12 0.050949
GW 260 7 -4 -2 10 -4 -6 10 0.050949
GW 261 7 -4 -6 10 -4 -10 10 0.050949
GW 265 3 -4 2 18 -4 2 16 0.050949
GW 266 3 -4 2 16 -4 2 14 0.050949
GW 267 3 -4 2 14 -4 2 12 0.050949
GW 268 3 -4 2 12 -4 2 10 0.050949
GW 269 3 -4 2 10 -4 2 8 0.050949
GW 270 3 -4 2 8 -4 2 6 0.050949
GW 271 3 -4 2 6 -4 2 4 0.050949
GW 272 3 -4 2 4 -4 2 2 0.050949
GW 273 3 -4 2 2 -4 2 -2.185e-15 0.050949
GW 274 3 -4 2 -2.185e-15 -4 2 -2 0.050949
GW 275 3 -4 2 -2 -4 2 -4 0.050949
GW 276 3 -4 2 -4 -4 2 -6 0.050949
GW 277 3 -4 2 -6 -4 2 -8 0.050949
GW 278 3 -4 2 -8 -4 2 -10 0.050949
GW 279 3 -4 2 -10 -4 2 -12 0.050949
GW 280 3 -4 2 -12 -4 2 -14 0.050949
GW 281 3 -4 2 -14 -4 2 -16 0.050949
GW 282 3 -4 2 -16 -4 2 -18 0.050949
GW 285 3 -4 6 18 -4 6 16 0.050949
GW 286 3 -4 6 16 -4 6 14 0.050949
GW 287 3 -4 6 14 -4 6 12 0.050949
GW 288 3 -4 6 12 -4 6 10 0.050949
GW 289 3 -4 6 10 -4 6 8 0.050949
GW 290 3 -4 6 8 -4 6 6 0.050949
GW 291 3 -4 6 6 -4 6 4 0.050949
GW 292 3 -4 6 4 -4 6 2 0.050949
GW 293 3 -4 6 2 -4 6 -2.185e-15 0.050949
GW 294 3 -4 6 -2.185e-15 -4 6 -2 0.050949
GW 295 3 -4 6 -2 -4 6 -4 0.050949
GW 296 3 -4 6 -4 -4 6 -6 0.050949
GW 297 3 -4 6 -6 -4 6 -8 0.050949
GW 298 3 -4 6 -8 -4 6 -10 0.050949
GW 299 3 -4 6 -10 -4 6 -12 0.050949
GW 300 3 -4 6 -12 -4 6 -14 0.050949
GW 301 3 -4 6 -14 -4 6 -16 0.050949
GW 303 3 -4 10 18 -4 10 16 0.050949
GW 304 3 -4 10 16 -4 10 14 0.050949
GW 305 3 -4 10 14 -4 10 12 0.050949
GW 306 3 -4 10 12 -4 10 10 0.050949
GW 307 3 -4 10 10 -4 10 8 0.050949
GW 308 3 -4 10 8 -4 10 6 0.050949
GW 309 3 -4 10 6 -4 10 4 0.050949
GW 310 3 -4 10 4 -4 10 2 0.050949
GW 311 3 -4 10 2 -4 10 -2.185e-15 0.050949
GW 312 3 -4 10 -2.185e-15 -4 10 -2 0.050949
GW 313 3 -4 10 -2 -4 10 -4 0.050949
GW 314 3 -4 10 -4 -4 10 -6 0.050949
GW 315 3 -4 10 -6 -4 10 -8 0.050949
GW 316 3 -4 10 -8 -4 10 -10 0.050949
GW 317 3 -4 10 -10 -4 10 -12 0.050949
GW 318 3 -4 10 -12 -4 10 -14 0.050949
GW 319 3 -4 10 -14 -4 10 -16 0.050949
GW 320 3 -4 10 -16 -4 10 -18 0.050949
GW 340 3 -4 6 -16 -4 6 -18 0.050949
GW 348 7 -4 10 18 -4 6 18 0.050949
GW 349 7 -4 6 18 -4 2 18 0.050949
GW 351 7 -4 10 16 -4 6 16 0.050949
GW 352 7 -4 6 16 -4 2 16 0.050949
GW 354 7 -4 10 14 -4 6 14 0.050949
GW 355 7 -4 6 14 -4 2 14 0.050949
GW 360 7 -4 10 -18 -4 6 -18 0.050949
GW 361 7 -4 6 -18 -4 2 -18 0.050949
GW 363 7 -4 10 -16 -4 6 -16 0.050949
GW 364 7 -4 6 -16 -4 2 -16 0.050949
GW 366 7 -4 10 -14 -4 6 -14 0.050949
GW 367 7 -4 6 -14 -4 2 -14 0.050949
GW 369 7 -4 10 8 -4 6 8 0.050949
GW 370 7 -4 6 8 -4 2 8 0.050949
GW 372 7 -4 10 6 -4 6 6 0.050949
GW 373 7 -4 6 6 -4 2 6 0.050949
GW 375 7 -4 10 4 -4 6 4 0.050949
GW 376 7 -4 6 4 -4 2 4 0.050949
GW 378 7 -4 10 2 -4 6 2 0.050949
GW 379 7 -4 6 2 -4 2 2 0.050949
GW 381 7 -4 10 -2 -4 6 -2 0.050949
GW 382 7 -4 6 -2 -4 2 -2 0.050949
GW 384 7 -4 10 -2.185e-15 -4 6 -2.185e-15 0.050949
GW 385 7 -4 6 -2.185e-15 -4 2 -2.185e-15 0.050949
GW 387 7 -4 10 -4 -4 6 -4 0.050949
GW 388 7 -4 6 -4 -4 2 -4 0.050949
GW 390 7 -4 10 -6 -4 6 -6 0.050949
GW 391 7 -4 6 -6 -4 2 -6 0.050949
GW 393 7 -4 10 -8 -4 6 -8 0.050949
GW 394 7 -4 6 -8 -4 2 -8 0.050949
GW 396 7 -4 10 -10 -4 6 -10 0.050949
GW 397 7 -4 6 -10 -4 2 -10 0.050949
GW 399 7 -4 10 -12 -4 6 -12 0.050949
GW 400 7 -4 6 -12 -4 2 -12 0.050949
GW 402 7 -4 10 12 -4 6 12 0.050949
GW 403 7 -4 6 12 -4 2 12 0.050949
GW 405 7 -4 10 10 -4 6 10 0.050949
GW 406 7 -4 6 10 -4 2 10 0.050949
GW 429 7 -4 -2 -18 -4 2 -18 0.050949
GW 430 7 -4 -2 -16 -4 2 -16 0.050949
GW 431 7 -4 -2 -14 -4 2 -14 0.050949
GW 432 7 -4 -2 -12 -4 2 -12 0.050949
GW 433 7 -4 -2 -10 -4 2 -10 0.050949
GW 434 7 -4 -2 -8 -4 2 -8 0.050949
GW 435 7 -4 -2 -6 -4 2 -6 0.050949
GW 436 7 -4 -2 -4 -4 2 -4 0.050949
GW 437 7 -4 -2 -2 -4 2 -2 0.050949
GW 438 7 -4 -2 0 -4 2 -2.185e-15 0.050949
GW 439 7 -4 -2 2 -4 2 2 0.050949
GW 440 7 -4 -2 4 -4 2 4 0.050949
GW 441 7 -4 -2 6 -4 2 6 0.050949
GW 442 7 -4 -2 8 -4 2 8 0.050949
GW 443 7 -4 -2 10 -4 2 10 0.050949
GW 444 7 -4 -2 12 -4 2 12 0.050949
GW 445 7 -4 -2 14 -4 2 14 0.050949
GW 446 7 -4 -2 16 -4 2 16 0.050949
GW 447 7 -4 -2 18 -4 2 18 0.050949
GS 0 0 0.0254 ' All in in.
GE 0
EK
LD 5 0 0 0 5.8e7 0
EX 0 1 1 0 1 0
GN -1
FR 0 38 0 0 470 6
RP 0 1 61 1001 90 0 3 6 10000 0
EN
On another note, I suppose it was inevitable, a rock group called Antennas, heh :
http://profile.myspace.com/index.cfm?fuseaction=user.viewprofile&friendid=54660168
