#241 |
x-240 is very hard to get swr<3 at 174mhz but im stil trying with a gain of 11dbi
#242 |
Yeah, it does improve vhf-hi over my post 20 here: http://www.digitalhome.ca/forum/show...t=99907&page=2
But, it knocks the uhf gain curve for a loop, heh.
#243 |
dang 300ohms wish i would have seen your VHF_Hi before i started out and your pics now
i"ll see if NARODs can improve what you have done Mite take me sometime but i like to play. Now i have 2 models to go at thank you. Well I'm working on the VHF_HI then I work on the SWR for the UHF that 473 looks to be fun |
#244 |
Ramkats tophat NAROD gets rid of the dip in the uhf gain curve, and changes the SWR, but I havent modeled a vhf-hi general purpose version of it yet.
#245 |
x-240 was lots of fun I now have the SWR <2 on VHF_HI with a gain of 9 to 10 dbi , UHF SWR <3 from 470 to 585 at time of 4Nec2 test. The gain is not that great in the UHF ,
I have not test colrods yet but i believe it may have to do with the 8 inch stubs for the gain in the UHF frequence. But so far very pleased with the resaults . To 300ohm's Ramkats tophat NAROD i have not modeled yet but to use them they could be used on the top and bottom of the element layout the middle would not be needed ,I believe Code:
CM 300ohms DBGH no reflector CM 88mm feedgap CM 10 gauge phasing line with 2 inch phasing line gap, 1 inch high CM SWR <2 VHF_HI SWR <3 UHF edit by WildWillie CM work in progress for higher gain in the UHF CE GW 30 5 0 1.65338786 -15.51916 0 6.65338786 -10.51916 0.06424494 GW 31 5 0 1.65338786 -5.5191602 0 6.65338786 -10.51916 0.06424494 GW 32 5 0 1.65338786 -5.5191602 0 6.65338786 -0.5191602 0.06424494 GW 34 5 0 -1.8111791 -15.51916 0 -6.8111791 -10.51916 0.06424494 GW 35 5 0 -1.8111791 -5.5191602 0 -6.8111791 -10.51916 0.06424494 GW 36 5 0 -1.8111791 -5.5191602 0 -6.8111791 -0.5191602 0.06424494 GW 38 5 0 1.65338786 -15.51916 0 6.65338786 -20.51916 0.06424494 GW 39 5 0 1.65338786 -25.51916 0 6.65338786 -20.51916 0.06424494 GW 40 5 0 1.65338786 -25.51916 0 6.65338786 -30.51916 0.06424494 GW 42 5 0 -1.8111791 -15.51916 0 -6.8111791 -20.51916 0.06424494 GW 43 5 0 -1.8111791 -25.51916 0 -6.8111791 -20.51916 0.06424494 GW 44 5 0 -1.8111791 -25.51916 0 -6.8111791 -30.51916 0.06424494 GW 46 7 0 6.65338786 0.48083979 0 14.8422063 0.49963777 0.06424494 GW 47 7 0 -6.8111791 0.48083979 0 -15 0.5 0.06424494 GW 55 5 0 -6.8111791 0.48083979 0 -1.8111791 5.48083979 0.06424494 GW 56 5 0 6.65338786 0.48083979 0 1.65338786 5.48083979 0.06424494 GW 57 5 0 -6.8111791 30.4808398 0 -1.8111791 25.4808398 0.06424494 GW 58 5 0 6.65338786 30.4808398 0 1.65338786 25.4808398 0.06424494 GW 61 5 0 -1.8111791 5.48083979 0 -6.8111791 10.4808398 0.06424494 GW 62 5 0 1.65338786 5.48083979 0 6.65338786 10.4808398 0.06424494 GW 66 5 0 1.65338786 15.4808398 0 6.65338786 20.4808398 0.06424494 GW 67 5 0 -6.8111791 20.4808398 0 -1.8111791 25.4808398 0.06424494 GW 68 5 0 6.65338786 20.4808398 0 1.65338786 25.4808398 0.06424494 GW 69 5 0 1.65338786 15.4808398 0 6.65338786 10.4808398 0.06424494 GW 100 7 0 6.65338786 30.4808398 0 14.9211044 30.4808398 0.06424494 GW 101 7 0 -6.8111791 30.4808398 0 -15.078896 30.4808398 0.06424494 GW 103 7 0 6.65338786 -0.5191602 0 14.8422063 -0.5003622 0.06424494 GW 104 7 0 -6.8111791 -0.5191602 0 -14.999997 -0.5 0.06424494 GW 106 7 0 6.65338786 -30.51916 0 14.9211044 -30.51916 0.06424494 GW 107 7 0 -6.8111791 -30.51916 0 -15.078896 -30.51916 0.06424494 GW 121 1 0 -1.8111791 -15.51916 1 -1.0788956 -15.51916 0.0511811 GW 127 5 0 -6.8111791 20.4808398 0 -1.8111791 15.4808398 0.06424494 GW 128 5 0 -6.8111791 10.4808398 0 -1.8111791 15.4808398 0.06424494 GW 129 1 0 -1.8111791 15.4808398 1 -1.0788956 15.4808398 0.0511811 GW 110 1 0 1.65338786 -15.51916 1 0.9211044 -15.51916 0.0511811 GW 130 11 1 -1.0788956 15.4808398 1 -1.0788956 -0.0191602 0.0511811 GW 131 1 0 1.65338786 15.4808398 1 0.9211044 15.4808398 0.0511811 GW 132 11 1 0.9211044 15.4808398 1 0.9211044 -0.0191602 0.0511811 GW 133 11 1 -1.0788956 -0.0191602 1 -1.0788956 -15.51916 0.0511811 GW 134 11 1 0.9211044 -0.0191602 1 0.9211044 -15.51916 0.0511811 GW 135 1 1 -1.0788956 -0.0191602 1 0.9211044 -0.0191602 0.077 GW 137 23 0 -15.105524 0.01991814 0 14.8944768 0.01991814 0.16243037 GW 138 23 0 -16.367851 -31.26916 0 15.3821497 -31.26916 0.16243037 GW 139 9 0 -5.136885 29.6617992 0 5.48145952 29.6617992 0.16243037 GW 140 9 0 -5.4524661 -29.817157 0 5.16587802 -29.817157 0.16243037 GW 141 9 0 -4.8213023 20.2028839 0 5.7970418 20.2028839 0.16243037 GW 142 9 0 -4.9790928 -20.678878 0 5.63925125 -20.678878 0.16243037 GW 143 5 0 -3.5589743 10.4233256 0 3.90355086 10.4233256 0.16243037 GW 144 5 0 -3.7167649 -10.57868 0 3.7457607 -10.57868 0.16243037 GW 145 25 -10 -16.71006 31 -10 16.3022669 31 0.16243037 GW 146 25 -10 -16.77564 -29.869738 -10 16.2366858 -29.869738 0.1624304 GW 147 27 -10 -19.44576 0.4604224 -10 17.566537 0.4604224 0.1624304 GW 148 23 0 -16.024458 31.1524063 0 15.7255422 31.1524063 0.16243037 GW 149 21 -10 -14.525443 38.9208413 -10 13.910948 38.9208413 0.16243037 GW 150 21 -10 -13.973176 -38.107615 -10 14.463215 -38.107615 0.16243037 GW 151 23 -10 -16.02447 -31.592988 -10 16.041126 -31.592988 0.1624304 GW 152 23 -10 -16.024476 32.9701405 -10 16.041124 32.9701405 0.16243037 GW 153 23 -10 -15.55109 34.8939854 -10 15.514515 34.8939854 0.1624304 GW 154 23 -10 -15.55109 -34.639078 -10 15.514515 -34.639078 0.1624304 GW 155 23 -10 -15.10335 36.8178393 -10 14.9622461 36.8178393 0.1624304 GW 156 23 -10 -14.60434 -36.402605 -10 15.4612602 -36.402605 0.16243037 GW 157 9 -5.55 -5.8683429 16 -5.55 6 16 0.1624304 GW 158 9 -5.55 -6 15 -5.55 5.86834252 15 0.1624304 GW 159 9 -5.55 -6 -14 -5.55 5.86834331 -14 0.1624304 GW 160 9 -5.55 -6 -16 -5.55 5.8683437 -16 0.1624304 GW 161 13 -5.55 -8.391 22 -5.55 8 22 0.1624304 GW 162 13 -5.55 -8 8 -5.55 9.391 8 0.1624304 GW 163 13 -5.55 -8 -8 -5.55 9.391 -8 0.1624304 GW 164 13 -5.55 -8.391 -23 -5.55 8 -23 0.1624304 GW 165 11 -5.55 -7.4916 19 -5.55 7 19 0.1624304 GW 166 9 -5.55 -6 13 -5.55 6.916 13 0.1624304 GW 167 9 -5.55 -6 -12 -5.55 6.4916 -12 0.1624304 GW 168 11 -5.55 -7.916 -19 -5.55 7 -19 0.1624304 GW 169 13 -5.55 -9 17 -5.55 8.916 17 0.1624304 GW 170 9 -5.55 -6 12 -5.55 6.4916 12 0.1624304 GW 171 9 -5.55 -6.916 -11 -5.55 6 -11 0.1624304 GW 172 13 -5.55 -9 -18 -5.55 8.4916 -18 0.1624304 GW 173 27 -10 -19 12 -10 18.012297 12 0.1624304 GW 174 27 -10 -19 -12 -10 18.012297 -12 0.1624304 GW 175 27 -10 -19 4 -10 18.012297 4 0.1624304 GW 176 27 -10 -19 -3 -10 18.012297 -3 0.1624304 GS 0 0 0.0254 ' All in in. GE 0 EK LD 5 0 0 0 3.77e7 0 EX 0 135 1 0 1 0 GN -1 FR 0 1 0 0 170 0 RP 0 1 10 1510 90. 0. 0. 20. 0. 0. |
#246 |
Hi,
Here is a design for a 75 ohm-direct connect Hoverman-like antenna. Because the bandwidth is limited, it optimized it for 475-600 MHz. Later I will post a model for the higher frequencies. The net gain peaks at about 15.6 dBi near 550 MHz. Because no matching transformer is required, there is no loss associated with one. Although it is a direct-connect antenna, a careful person would attach the coax through a 1-1 balun to avoid feedline currents. But such baluns are not easy to come by and at these frequencies, could limit the bandwidth. If it were me, I would forego the balun. The dGain column in the table below represents the difference between the NetGain and RawGain columns, and reflects the mismatch loss between the coax and the antenna. The NetGain has been AGT corrected. Code:
freq[MHz] SWR RawGain NetGain dGain F/B
471.25 3.73766 14.71 12.9453 -1.76468 9.11
477.25 3.1019 14.8893 13.5665 -1.32283 9.21
483.25 2.62622 15.0583 14.0831 -0.975173 9.33
489.25 2.29346 15.2269 14.4994 -0.727536 9.5
495.25 2.08988 15.3854 14.8083 -0.577022 9.7
501.25 1.99922 15.5338 15.0228 -0.510963 9.93
507.25 1.99592 15.6724 15.1638 -0.508575 10.2
513.25 2.04538 15.8013 15.2568 -0.544489 10.51
519.25 2.11114 15.9109 15.3183 -0.592623 10.86
525.25 2.16111 15.9915 15.3621 -0.629427 11.23
531.25 2.17052 16.0432 15.4068 -0.636372 11.64
537.25 2.12363 16.0561 15.4543 -0.601806 12.07
543.25 2.01527 16.0303 15.5077 -0.52259 12.53
549.25 1.85103 15.9655 15.5602 -0.405303 13.02
555.25 1.64573 15.8715 15.6047 -0.266725 13.52
561.25 1.4196 15.7278 15.5952 -0.132611 14.01
567.25 1.19364 15.554 15.52 -0.0339743 14.47
573.25 1.0218 15.3299 15.3294 -0.00050478 14.85
579.25 1.24655 15.0753 15.0226 -0.0526255 15.13
585.25 1.53094 14.78 14.5846 -0.195456 15.27
591.25 1.87293 14.4641 14.0434 -0.420688 15.14
597.25 2.30236 13.8344 13.1002 -0.734156 13.53
Code:
CM Model: DC-8-UHFlo CE GW 1 19 0.101018 -0.0392186 0 0.101018 0.0392186 0 0.00205769 GW 2 19 0.101018 -0.0392186 0 0.0591873 -0.113347 0 0.00205769 GW 3 19 0.101018 0.0392186 0 0.0591873 0.113347 0 0.00205769 GW 4 25 0.101018 -0.0392186 0 0 -0.0127103 0 0.00205769 GW 5 25 0.101018 0.0392186 0 0 0.0127103 0 0.00205769 GW 6 103 0 -0.0127103 0 0 -0.344589 0.274073 0.00205769 GW 7 103 0 -0.0127103 0 0 -0.344589 -0.274073 0.00205769 GW 8 103 0 0.0127103 0 0 0.344589 0.274073 0.00205769 GW 9 103 0 0.0127103 0 0 0.344589 -0.274073 0.00205769 GW 10 59 0 -0.344589 0.274073 0 -0.153102 0.432208 0.00205769 GW 11 59 0 -0.344589 -0.274073 0 -0.153102 -0.432208 0.00205769 GW 12 59 0 0.344589 0.274073 0 0.153102 0.432208 0.00205769 GW 13 59 0 0.344589 -0.274073 0 0.153102 -0.432208 0.00205769 GW 14 45 0 -0.153102 0.432208 0 -0.29621 0.55039 0.00205769 GW 15 45 0 -0.153102 -0.432208 0 -0.29621 -0.55039 0.00205769 GW 16 45 0 0.153102 0.432208 0 0.29621 0.55039 0.00205769 GW 17 45 0 0.153102 -0.432208 0 0.29621 -0.55039 0.00205769 GW 18 23 0 -0.29621 0.55039 0 -0.397516 0.55039 0.00205769 GW 19 23 0 -0.29621 -0.55039 0 -0.397516 -0.55039 0.00205769 GW 20 23 0 0.29621 0.55039 0 0.397516 0.55039 0.00205769 GW 21 23 0 0.29621 -0.55039 0 0.397516 -0.55039 0.00205769 GW 22 87 -0.0867753 -0.6096 -0.544908 -0.0867753 0 -0.544908 0.0035 GW 23 87 -0.0867753 0 -0.544908 -0.0867753 0.6096 -0.544908 0.0035 GW 24 87 -0.0867753 -0.6096 -0.413654 -0.0867753 0 -0.413654 0.0035 GW 25 87 -0.0867753 0 -0.413654 -0.0867753 0.6096 -0.413654 0.0035 GW 26 87 -0.0867753 -0.6096 -0.267001 -0.0867753 0 -0.267001 0.0035 GW 27 87 -0.0867753 0 -0.267001 -0.0867753 0.6096 -0.267001 0.0035 GW 28 67 -0.0867753 -0.476333 -0.0984601 -0.0867753 0 -0.0984601 0.0035 GW 29 67 -0.0867753 0 -0.0984601 -0.0867753 0.476333 -0.0984601 0.0035 GW 30 67 -0.0867753 -0.476333 0.0984601 -0.0867753 0 0.0984601 0.0035 GW 31 67 -0.0867753 0 0.0984601 -0.0867753 0.476333 0.0984601 0.0035 GW 32 87 -0.0867753 -0.6096 0.267001 -0.0867753 0 0.267001 0.0035 GW 33 87 -0.0867753 0 0.267001 -0.0867753 0.6096 0.267001 0.0035 GW 34 87 -0.0867753 -0.6096 0.413654 -0.0867753 0 0.413654 0.0035 GW 35 87 -0.0867753 0 0.413654 -0.0867753 0.6096 0.413654 0.0035 GW 36 87 -0.0867753 -0.6096 0.544908 -0.0867753 0 0.544908 0.0035 GW 37 87 -0.0867753 0 0.544908 -0.0867753 0.6096 0.544908 0.0035 GE 0 EK 0 FR 0 39 0 0 471.25 6 EX 0 1 10 0 1 GN -1 0 0 0 0.0 0.0 0.0 0.0 0.0 0.0 RP 0 60 73 1001 0 0 3 5 EN Last edited by stampeder; 2009-08-11 at 04:11 PM. Reason: This design will be "X-246" in our naming convention :) |
#247 | |
Of course, I have no test equipment. I have to judge comparing a 2dbi (stated) Rosewill rubber ducky antenna which is connected up with a meter of RG174U coax, which easily knocks a dbi off, leaving about 1dbi at the wifi card input, heh. And in Ubuntu, I use RutiL for the signal measurement. My biquads, per modeling, should be about 10 to 11 dbi. They are connected up with 2 meters of RG58U coax, also a loss of about a dbi, but better than RG174U. My builds are pretty exacting, I would say within .5mm. (Will post pictures of latest build later) But, all in all, Im not seeing the 9 dbi difference in gain I should. I think a good portion of that may be due to a lack of balun.
#248 | ||
preamp. It seems to me that much of the feedline radiation could be choked off by properly choosing the length of cable connecting the antenna to the preamp. Also the coax should drop vertically from the feed point and be properly centered. Quote:
Also, how confident are you in the accuracy of NEC-2 at such frequencies? Thanks, --John |
#249 |
John: What is the stuff in the +X? The first part could be a 1/4 wave matching section, but what are the tails(another 1/4 wave stub)?
#250 | ||
Others have done some pretty good analysis on the Trevor Marshall 2.4Ghz biquad too. http://www.lecad.uni-lj.si/~leon/other/wlan/biquad/ I followed those guidelines on my last build.
#251 |
#252 |
As promised, here is a 75 ohm design optimized for the 600-700 MHz
band. Ideally, it should be used with a 1-1 balun (see the earlier discussion). The netgain near 16 dBi over much of the band. Code:
597.25 2.29267 15.5086 14.7817 -0.726948 8.96
603.25 2.05005 15.2912 14.7433 -0.547893 10.16
609.25 2.08993 15.6546 15.0775 -0.577057 8.48
615.25 1.70381 16.1806 15.8758 -0.304714 7.99
621.25 1.54366 16.3003 16.0973 -0.203063 8.26
627.25 1.51274 16.3601 16.1754 -0.184706 8.59
633.25 1.55366 16.41 16.2009 -0.209104 8.97
639.25 1.61952 16.4404 16.1904 -0.249972 9.38
645.25 1.67786 16.4417 16.1541 -0.287597 9.8
651.25 1.70855 16.4242 16.1163 -0.307862 10.26
657.25 1.70052 16.3781 16.0756 -0.30253 10.74
663.25 1.65007 16.3034 16.0339 -0.269526 11.25
669.25 1.56028 16.1899 15.9768 -0.213122 11.77
675.25 1.43962 16.0474 15.904 -0.143366 12.31
681.25 1.30052 15.8653 15.7906 -0.0747478 12.86
687.25 1.16002 15.6534 15.6295 -0.0239009 13.4
693.25 1.08157 15.4212 15.4145 -0.00667341 13.92
699.25 1.19755 15.1584 15.1231 -0.0352388 14.41
Code:
CM Model: DC-8-UHFhi CE GW 1 13 0.0790197 -0.0307354 0 0.0790197 0.0307354 0 0.00205769 GW 2 17 0.0790197 -0.0307354 0 0.0460475 -0.0944725 0 0.00205769 GW 3 17 0.0790197 0.0307354 0 0.0460475 0.0944725 0 0.00205769 GW 4 19 0.0790197 -0.0307354 0 0 -0.0127175 0 0.00205769 GW 5 19 0.0790197 0.0307354 0 0 0.0127175 0 0.00205769 GW 6 89 0 -0.0127175 0 0 -0.303555 0.228222 0.00205769 GW 7 89 0 -0.0127175 0 0 -0.303555 -0.228222 0.00205769 GW 8 89 0 0.0127175 0 0 0.303555 0.228222 0.00205769 GW 9 89 0 0.0127175 0 0 0.303555 -0.228222 0.00205769 GW 10 45 0 -0.303555 0.228222 0 -0.151483 0.347555 0.00205769 GW 11 45 0 -0.303555 -0.228222 0 -0.151483 -0.347555 0.00205769 GW 12 45 0 0.303555 0.228222 0 0.151483 0.347555 0.00205769 GW 13 45 0 0.303555 -0.228222 0 0.151483 -0.347555 0.00205769 GW 14 37 0 -0.151483 0.347555 0 -0.271706 0.441894 0.00205769 GW 15 37 0 -0.151483 -0.347555 0 -0.271706 -0.441894 0.00205769 GW 16 37 0 0.151483 0.347555 0 0.271706 0.441894 0.00205769 GW 17 37 0 0.151483 -0.347555 0 0.271706 -0.441894 0.00205769 GW 18 15 0 -0.271706 0.441894 0 -0.341595 0.441894 0.00205769 GW 19 15 0 -0.271706 -0.441894 0 -0.341595 -0.441894 0.00205769 GW 20 15 0 0.271706 0.441894 0 0.341595 0.441894 0.00205769 GW 21 15 0 0.271706 -0.441894 0 0.341595 -0.441894 0.00205769 GW 22 85 -0.0635445 -0.597882 -0.450593 -0.0635445 0 -0.450593 0.0035 GW 23 85 -0.0635445 0 -0.450593 -0.0635445 0.597882 -0.450593 0.0035 GW 24 87 -0.0635445 -0.6096 -0.374587 -0.0635445 0 -0.374587 0.0035 GW 25 87 -0.0635445 0 -0.374587 -0.0635445 0.6096 -0.374587 0.0035 GW 26 83 -0.0635445 -0.592336 -0.257565 -0.0635445 0 -0.257565 0.0035 GW 27 83 -0.0635445 0 -0.257565 -0.0635445 0.592336 -0.257565 0.0035 GW 28 51 -0.0635445 -0.366453 -0.0995267 -0.0635445 0 -0.0995267 0.0035 GW 29 51 -0.0635445 0 -0.0995267 -0.0635445 0.366453 -0.0995267 0.0035 GW 30 51 -0.0635445 -0.366453 0.0995267 -0.0635445 0 0.0995267 0.0035 GW 31 51 -0.0635445 0 0.0995267 -0.0635445 0.366453 0.0995267 0.0035 GW 32 83 -0.0635445 -0.592336 0.257565 -0.0635445 0 0.257565 0.0035 GW 33 83 -0.0635445 0 0.257565 -0.0635445 0.592336 0.257565 0.0035 GW 34 87 -0.0635445 -0.6096 0.374587 -0.0635445 0 0.374587 0.0035 GW 35 87 -0.0635445 0 0.374587 -0.0635445 0.6096 0.374587 0.0035 GW 36 85 -0.0635445 -0.597882 0.450593 -0.0635445 0 0.450593 0.0035 GW 37 85 -0.0635445 0 0.450593 -0.0635445 0.597882 0.450593 0.0035 GE 0 EK 0 FR 0 39 0 0 471.25 6 EX 0 1 7 0 1 GN -1 0 0 0 0.0 0.0 0.0 0.0 0.0 0.0 RP 0 60 73 1001 0 0 3 5 EN --John |
#253 |
Hello everyone, recently I made an antenna from a thick copper electrical wire. It is vertically oriented in “double bi-quad” shape with 120 mm between center lines of each square side. There is a reflector located behind the antenna. This reflector is made of pretty dense galvanized mesh 10mm x 10mm. The distance is 67 mm from the center line of the antenna to the mesh. The antenna feed is connected with 4:1 balun in the middle made of RG-59 TV-cable. It works exceptionally well and pulls in just under 20 stations. I can not evaluate this antenna and ask for help if someone with proper knowledge would run this setup through any digital simulation program. Any help is appreciated -- thanks.
#254 |
Basically, a biquad with solid reflector produces about 10 to 11 dbi in gain, with a nice wide round pattern. A double biquad, about 13 dbi, but if all quads are the same, the bandwidth is low. Look here, post 32 and 34, for a wide band double biquad type : http://www.digitalhome.ca/forum/show...=105660&page=3
#255 |
Bob
what instructions were you building from that says to connect a 4:1 balun to the feed point of a “double bi-quad” ??? |
