I mounted a 4' piece of ABS pipe to the back of my SBGH to mount it to my flagpole temporarily. My question is, can i use a metal mast pipe when i install it my tower and rotor? If anyone is curious it cost me $ 57.50 to build a SBGH, from scratch.
Last edited by stampeder; 2009-04-10 at 03:04 PM. Reason: moved from Peterborough thread |
#2 | |
Yeah, I modeled a 1 1/4 inch typical mast on the SBGH and its OK. Make sure the colinear rods or reflector sections dont short out on the metal mast.
Thank's 300ohm. I did shop around , home Depot,Can. tire, HomeHardware, etc. that's just the difference between Canada and the US. I even stripped the 10-2 wire. A 4bay antenna up here is about $90.00 +ship. so i figure that's not to bad. I would not build a DBGH , if you were to build the bottom sbgh stronger , say out of 3/4 " pvc, just double the price on pvc fitting's. Why did i get into this hobby, i am allready looking at building a Gen2 sbgh gh10,(found some real cheap parts) guess i'm hooked on this now.LOL Thank's again: swampdogger.
#4 | |
Ya, probably so, i just found 50' of 3/16" soft copper tube in my basement i didn't know i had, why would that not work for my elements? I just tore down my old tv antenna to-day , thinking of using the reflector's also, hmmm , this is getting cheaper allready.
#6 | ||
