windows media centre - Canadian TV, Computing and Home Theatre Forums
Old 2009-04-08, 08:31 PM   #1
hookup11
Default windows media centre
if i have windows xp and purchase a mce remote with the ir blaster etc... Do i need any software to use the remote solely for windows media player or does it only work with the windows media center program.
hookup11 is offline
Old 2009-04-14, 06:49 PM   #2
jeneral
You should look into Eventghost. I configured Eventghost for a friend to use with XBMC and it is very flexible and free. While you're at it, you should look into XBMC. Windows Media Player is very basic.
jeneral is offline
Old 2009-04-14, 07:23 PM   #3
pnear
The controls for Play, Stop, Fast forward, etc will work with Media Player as well. Clicking on the Green Button or My Music will bring up the Media Center interface.
pnear is offline
