CM4221HD Hardware Hacks - Canadian TV, Computing and Home Theatre Forums
Old 2009-04-06, 12:51 AM   #1
ota_canuck
Location: Dunnville, Ontario on the Grand River, North shore Lake Erie
Thumbs up CM4221HD Hardware Hacks
My secret little CM4221HD hack.
[note: this hack has been tried and true over a dozen times]
Just thought I should share something with those of you who are stuck on the performance benefits of that old reliable CM4221 antenna design.
Here’s a little hack that I have been doing for a while now in order to beef up the new CM4221HD antenna design.
It appears that whoever it was at PCT in China that was responsible for the re-design of the new CM4221HD was more concerned with the cosmetic values of this newly designed antenna than it’s overall performance values.
There has been some concern among many about the lacking performance of the new CM4221HD antennas as compared to the old CM4221 antenna design. There are a few simple revisions that can be made to the CM4221HD that will restore those overall performance values and restore the familiar characteristics that the old CM4221 antenna had.
‘V’ ELEMENT OBSTRUCTIONS:
There are some cute little 1” plastic covers that hide a portion of the elements at the connection points of each ‘V’ element on each bay. Remove these 8 cosmetic plastic caps and just toss them away, as they actually shorten the overall calculated length of each ‘V’ element by almost 2”.
RESIZE THE REFLECTOR GRID WIDTH:
The next thing that will need some adjustment is the width of the 24” wide reflector grid. The new CM4221HD reflector grid is 24” wide and the old CM4221 is only 20” wide. To do this, just carefully remove the plastic side retainers from all of those grid rods. Then cut exactly 2” off each of the aluminium grid rods and then reinstall the plastic side retainers.
BALUN TO BOOM CLEARANCE:
The flat bars that the balun box is connected to are too close to the boom, so simply pull the balun assembly outwards and make sure that those flat bars are at least ½” away from the boom. I believe this may have just been an oversight that should have been mentioned within the antenna assembly instruction sheet.
[I believe this inward positioning of the balun was intended to accommodate the slim packaging dimensions and to reduce the risk of shipping damages]
You will now have the same basic dimensional and performance characteristics of the original CM4221 antenna design.
ota_canuck is offline
Old 2009-04-06, 01:50 AM   #2
300ohm
That one I wouldnt do. Instead I would increase its width to 32 to 44 or so inches to pick up vhf-hi.
300ohm is offline
Old 2009-04-06, 02:37 AM   #3
ota_canuck
Default more directional or more mult-directional?
Does a wider reflector actually make the CM4221 design more directional or more mult-directional? Either way that you choose to go with the reflector width, I have found that the forward gain on the center lobe remains about equal distance, whereas the forward lobes and outer lobes are much broader when using the narrower reflector width. The old 4221 design was more multi-directional for those who desired to receive from various broadcast tower locations without the use of a rotor.
When using the old CM4221 desin, I could get Erie PA WQLN and WSEE at 80-100% without making any antenna aiming adjustments. With the new CM4221, I could only receive either WSEE or WQLN by rotating the antenna back and forth by about 10 degrees, and the best reception I could get on either channel was 60% signal strength. When I modify the new CM4221 antenna as stated, I get the same results as I got with the old CM4221 design.
As far as VHF-Hi, I have found that the old CM4221 design was already pretty good at picking up analog channels VHF-5 through UHF-66. I suppose the new wider reflector design was intended to improve the VHF-Hi at the expense of losing some of the multi-directional qualities and the higher freqs above UHF-50.
Old 2009-04-06, 07:34 AM   #4
300ohm
I think thats going to depend on which channels.
Channel 5 ?? You must have very strong vhf signals. Post your TVFool. The 4 bay bowtie doesnt really kick in with really good vhf-hi gain until the reflector width is above 28-32 inches or so.
The difference in vhf hi between the old 20 inch width and the new 24 inch width is pretty small.
300ohm is offline
Old 2009-04-06, 10:31 AM   #5
ManBOOYA
Being plastic, what affect do these caps have on the V element? (I'm going to try it when I get home)
I'll give this one a try too. How much of an Improvement do you see? If I remember correctly the bars go in towards the boom. I wonder what would happen if you flipped the bars over (or replaced them with something else) so the balun would move away from the boom?
ManBOOYA is offline
Old 2009-04-06, 12:13 PM   #6
stampeder
Is there a NEC file for the CM4221HD to see how these hardware hacks would model?
stampeder is offline
Old 2009-04-06, 12:59 PM   #7
300ohm
There should be soon. Ken Nist has been modeling the new CM stuff, so Im sure he'll post them soon. I stopped doing mine because, #1 I dont have the antenna in front of me and trying to get exact measurements etc for the model over the internet can be trying, heh.
300ohm is offline
Old 2009-04-06, 04:20 PM   #8
ota_canuck
Lightbulb stampeder: how these hardware hacks would model
These 4221 hacks have proven to work well for this area. Seeing a model of the modified antennas performance would assure us that this would work in other locations as well where a wider coverage area is desired.
Old 2009-04-06, 04:31 PM   #9
300ohm
Yep. Since you have the antennas in front of you, simply download 4nec2 for free and get busy, heh.
300ohm is offline
Old 2009-04-06, 04:39 PM   #10
stampeder
Exactly, modeling will help tell if even further tweaks to these hardware hacks are possible too.
Old 2009-04-06, 05:06 PM   #11
ota_canuck
Default 4nec2 modeling
I just downloaded the 4nec2 tools. Now,... if I can figure out how to use it
Old 2009-04-06, 05:17 PM   #12
stampeder
This is the thread to go to for 4NEC2 modeling:
http://www.digitalhome.ca/forum/showthread.php?t=83772
Old 2009-04-20, 01:52 PM   #13
firechkn
Any update on this? I wonder if there is any downside to doing these mods.
Since it was easy to do, I removed those plastic clips and raised the balun and it appears I got slightly better results. No instruments to test just my signal meter on the tv.
firechkn is offline
Old 2009-04-20, 10:20 PM   #14
ota_canuck
Narrowing the reflector grid by 4" will give your antenna a broader [45 deg.+] coverage area if that is the performance improvement you need. These modifications simply mimic the dimensions of the older 4221 design.
No performance measurement instruments are needed.
Realtime results that suit your needs mean more than any modeling or measuring devices.
Old 2009-04-21, 08:45 AM   #15
firechkn
I didn't like how distorted the flat bars looked once the balun was raised, the result was that the balun was sticking way out. Can this effect the signal any?
I decided to remove the bars, flatten them, mark and drill new holes. Now the balun is in level with the V elements. If nothing else, it looks better now.
Would narrowing the reflector grid decrease the forward gain any? I like the forward gain now, but would be nice to pickup some side gain without the sacrifice. I don't have an original 4221 to test.
firechkn is offline
OTA Forum Sponsor
