I'll be setting up my OTA hardware in the next week or so and I'm wondering if I could use the cable I was previously using with my Rogers internet service?
The cable is marked "18 AWG CM or CATV". What I need to know is if it's 75 ohm RG6. As this cable is already run exactly where I need it and to the correct length, any help confirming it's 75 ohm RG6 will save me alot of work and will be greatly appreciated. |
Pretty sure that is RG-59.
I believe that RG-59 can work though, especially if the run is not too long, it just has higher line losses:
http://www.digitalhome.ca/forum/showthread.php?t=3327
It's about 120' in length.
I think I'll mount my hardware and use the existing cable and see what the signal strength is like. If I encounter any problem, I'll replace it with RG6. ty for the help. |
The chart in the post 3 link indicates that at higher frequencies, you'd see a 10-15 dB additional drop at that length (RG59 vs RG6). So, it may depend on what sort of signal you have in the first place, or if you put an amp by the antenna, etc.
There are people much more experienced with OTA that should be able to comment further.
manolid if your house was built in the past 10 years, there is a pretty good chance its RG6. 18awg is thick and is the standard center core size for RG6 cable. My guess is that you have RG6.
RG59 is rated at 22 gauge for the center conductor. 120' of cable is pretty long and your ota signal will surely suffer. I would highly recommend a antenna preamp for your setup. Good luck.
CM4228/9521/7775;F.RmJvc70FH96/8300HDPvr/Dish 612;B.Rm LC52LE810UN/8642HD;Study LG50PK550/Xbox360; Last edited by Yaamon; 2007-06-01 at 03:35 PM. |
My house is 30 years old, but this cable was run by Rogers about ten years ago.
Ty for the help. |
If it was used for high speed internet service it is likely RG6. They need better signal strength for high speed internet over coax than analog TV.
#9 |
I just got some bulk quad shield rg6, some rg6 compression connectors, and a crimping tool. I'm having trouble getting a consistently good connection though.
I strip the cable, fold back the outer braiding, push the connector on using a T-tool, then crimp the connector. Four out of five times I can just slide the connector off after crimping. I think the problem is that I'm not getting the inner metal sleeve of the connector to slide between the insulated core of the cable and the outer jacket. I just seem to be pushing the jacked back. Does anyone have any tips on using the T-tool to push the connector onto stripped cable? And I did make sure the connectors were quad shield compatible, so that shouldn't be the problem. |
#10 |
timmy1, With compression connectors you need to use a compression tool, not a crimp tool. Home Depot sells two different models of compression tools by Ideal. I have the cheaper one and it works very well.
If you are using the correct tool, double check that you are using quad shield cable with your quad shield connectors. Quad shield cable has 4 layers of shield (2 layers of foil and 2 layers of braid alternating, i.e. foil, braid, foil, braid). If you only have dual shield RG6 you need to use dual shield connectors. When used properly, compression connectors should provide a very reliable connection. |
#11 |
Sorry I wasn't clear. The box and website describe it as a crimping tool, but it's made for compression connectors. Here's a pic:
![]() And I am using quad shield rg6 (it says so on the cable, and I also tore it apart to have a look). I feel like I'm doing something wrong. Maybe later I'll post some pics of my technique so it will be clearer what's happening. |
#12 |
A follow-up on my cable woes. Here's an image of the process I use:
![]() As you can see it's not working out so well for me. I have to use quite a bit of force to push the connector onto the cable, but it seems that I'm just pushing the insulation and the jacket back. Then when I use the compression tool it just pulls the connector forward again. As I mentioned in a previous post, I do get a solid connection every 4 or 5 tries. Any thoughts? |
#13 |
My guess is that it is an alignment issue. You have to make sure that the connector is lined up so that the centre core slides into the centre of the connector. Don't push too hard (at least not until you are sure that it is aligned properly). You then need to push the connector on so that the centre core is flush with the back of the connector (your second picture shows it back quite a bit). Only then should you compress the connector. I hope this helps.
#14 |
Thanks for the photo, timmy1: I think I see the problem here. The copper core wire and the stripped white portion of the coax are too long.
Do you have a coax stripping tool? If not, definitely get one so that you get a standard, correct measurement every time. Get a good one that allows you to set the depth of cut of the knives with an Allen wrench. That way you can set them very precisely. In the case of the photo, even if your compression tool actually made it fit, the problem is that every time you would screw in that coax end onto a female fitting the threaded nut portion would be pulled onto the female fitting in the inwards direction as we want, but the inner core of the coax would reach a stopping point on the female fitting at which it can no longer travel inwards, so it would act as a "pushing outwards" force opposite of the threaded portion. In that case your compression fitting would fail over a short time. |
#15 |
Hi stampeder the cable stripped does not look too bad.
This is what I noticed not sure if the connector already used. They are many different connectors on the market and only certian type of compression tool and connector will work together properly. The connector that you have in the picture it looks like its already been used, unless you just pulled it off and its sitting there, is there a 1/8" gap before compression? In this photo same type tool but the connector before it is compressed has about 1/8" the blue plastic ring before it compresses on the cable. ![]() http://www.pbase.com/yaamon/image/81316195 Using a compression tool and connectors that dont have a separate ring they compress internally. ![]() http://www.pbase.com/yaamon/image/81316196 Normally there should be a little resistance when you push the connector on and make sure the center( white insulator)is pushed flush to the inner part of the connector.
CM4228/9521/7775;F.RmJvc70FH96/8300HDPvr/Dish 612;B.Rm LC52LE810UN/8642HD;Study LG50PK550/Xbox360; Last edited by Yaamon; 2007-06-28 at 01:55 PM. |
