Echo Cancelling Tiles for High Ceilings - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Consumer Electronics and Home Computing > Home Theatre Corner > Home Theatre Construction
Old 2009-03-20, 08:00 PM   #1
Logan21
Default Echo Cancelling Tiles for High Ceilings
Hey Guys,
I heard of a product you can use which is a ceiling tile which hangs vertically from the ceiling rather than horizontal like with a drop ceiling. It serves to deaden echo in a room with high ceilings and only needs to be placed about 4 feet apart.
Has anyone seen this before, and tell me where I can get more info?
Logan21 is offline
Old 2009-03-20, 08:52 PM   #2
ScaryBob
I've seen this used in a number of commercial venues and it appears to work very well. Any sound absorbing material should work, such as heavy drape material or acoustic tiles. They could be cut to size. I don't think it matters much how they are hung.
ScaryBob is offline
