CM4228HD Hardware Hacks - Canadian TV, Computing and Home Theatre Forums
Old 2009-03-14, 09:49 PM   #1
Techluvr
Thumbs up CM4228HD Hardware Hacks
I modded my CM4228HD as per Ken Nist's excellent article. I removed the hex screws holding the rods with the plastic balun box. I added a separate balun to each of the two antenna sections and a combiner. Measured with a laptop at the antenna using WinTV's Digital Signal Quality Meter I saw an increase in SNR from 27 to 30. I receive 4 digital stations, all broadcast from Camp Fortune at about 30Km north. The analog VHF Hi stations are also very clear; the VHF lo are a bit fuzzy. I'm about 5Km from Herbert's Corners, the other local broadcast tower; it's to the south. The UHF analogue stations and Ch 11 are watchable, but a little fuzzy. They are being received from the back of the antenna! The whole rig is in the garage rafters on the north side of the house.
I then took a CM4221HD and removed the bowtie assembly. I mounted that to the back of the CM4228HD; I'll call it a CM4229HD. I added another combiner that merges this new antenna section with the output of the first combiner of the modded CM4228HD. I saw no loss in the SNR meter and the picture quality of the VHF-Hi & UHF analog stations in the north direction were all still excellent. But now the UHF and Ch11 from the southerly Herbert's Corners are also very good. There is a slight multi-path ghosting on some of them, but still watchable.
Next, I disconnected the laptop from the antenna and replaced it with the 20 metre cable that leads to the VHF/UHF input of an Eagle Aspen S-4180-GX+ multiswitch. It mixes the VHF/UHF signal with the input from the satellite LNAs and distributes it to TVs and radios around the house. The loss for VHF/UHF through the multi-switch is 5dB. The signal at the TV outlets was pretty degraded. I couldn't get 2 of the digital stations from the north; most of the analog stations were very fuzzy.
Next, I put a CM7777 preamp at the antenna. This seemed to overwhelm the input of the tuner. I added a cheapo splitter between the preamp power supply and the multiswitch as a 4dB attenuator. That seemed to clear things up pretty well.
So, I'll probably leave everything this way until Canada's digital switchover and decide if it's worth the effort of putting this rig outside.
Techluvr is offline   Quick reply to this message
Old 2009-03-16, 07:07 AM   #2
cadsulfide
Nice work!
Using the splitter as an attenuator is a good idea, I've had to use simular methods for my mini-headend to tone down modulator outputs.
cadsulfide is offline   Quick reply to this message
Old 2009-03-16, 03:05 PM   #3
stampeder
What is the URL to Ken Nist's article that you used?
stampeder is offline   Quick reply to this message
Old 2009-03-16, 03:18 PM   #4
Techluvr
http://www.hdtvprimer.com/ANTENNAS/TemporaryPage.html
Given the name "TemporaryPage" I imagine it will be moved at some time.
Old 2009-03-16, 03:23 PM   #5
stampeder
Nice hardware hack! This is just what the CM4228HD needed!
Old 2009-03-16, 11:44 PM   #6
tijaune
Location: Laval, uhf:cm4228hd preamp:cm7777/Emerson+2 way splitter tuner:LG,WinTV-hvr950
Thanks, I will definitively try this. Lately, I just tight wrap the balun inch back and lost uhf 43. It was no fun to examine the balun closer in the attic.
Techluvr,
I guess you have remove the 2 original horizontal rods where the square balun is connected to? I read somewhere that it is impossible to pop open the balun.
tijaune is offline   Quick reply to this message
Old 2009-03-17, 09:42 AM   #7
Techluvr
Originally Posted by tijaune View Post
Techluvr,
Yes, it's very easy to do. It can be removed with just a hex-nut driver. I was careful not to bend the rods in case I had to put it back together. As it turns out I won't need to do that because I think the modified antenna works better. Of course that's just my subjective observation. I'm going to try to back that up with some real numbers this week-end. I'll post my results here.
Old 2009-03-17, 09:46 AM   #8
Techluvr
Originally Posted by cadsulfide View Post
Nice work!
That was just a temporary fix. I bought 2 6dB attenuators from The Source; they're on special for $1.98 ea. This worked even better than the splitter.
Old 2009-03-17, 12:46 PM   #9
300ohm
I prefer the term Signal Discarding Devices, heh heh.
300ohm is offline   Quick reply to this message
Old 2009-03-17, 10:34 PM   #10
mlord
Reset Electronics in Ottawa also sells attenuators, which might be handy once Bell finishes their takeover of TSbCC.
cheers
mlord is offline   Quick reply to this message
Old 2009-03-21, 08:44 PM   #11
Techluvr
Default Modified 4228HD... Some real world numbers
My 'real world' is a CM4228HD mounted in the rafters of the garage. The mast is a 1" copper pipe that I can rotate 360 degrees. I am located between two broadcast towers almost 180 degrees apart. One is north ~30KM; one is south ~ 5KM.
I took two sets of measurements from every UHF channel from both towers; one set with the original CM4228HD and one set with the centre balun replaced by 2 individual baluns (-2.5dB ea) and a combiner (-.5dB). The <10M cable losses and any other incidental connector losses are the same for both setups, so I ignore them. I took an additional set of measurements with a CM4221HD for only the south facing stations.
All numbers are dBm rounded to the nearest whole number.
Code:
    Ch        Orig    Mod   4221HD
    14        -33     -34     -29
    20        -58     -58
    22        -52     -56
    24        -44     -42
    25        -50     -48
    30        -47     -45
    34        -51     -53
    40        -57     -58
    43        -50     -48     -44
    60        -60     -54     -53
    65        -57     -48     -48
Not fantastic; but for the most part, the modification is an improvement over the original. The 4221HD did just as well if not slightly better. Maybe if I have time, I'll swing the 4221HD north and see how it does on those stations.
Last edited by stampeder; 2009-03-22 at 01:11 PM. Reason: added CODE tags to table for clarity
Old 2009-03-22, 07:46 AM   #12
Muus
Techluvr, what are you using to obtain those dBm values?
Muus is offline   Quick reply to this message
Old 2009-03-22, 09:20 AM   #13
Techluvr
A spectrum analyzer that I borrowed from work for the week-end.
Old 2009-03-22, 09:31 AM   #14
300ohm
You might as well post the make and model number too, heh.
Old 2009-03-22, 10:11 AM   #15
Techluvr
It's an Agilent E4402B. It's an 'economy' model; that's why they let me take it.
The procedure ( I'm sure that's the next question )...
Set the frequency to capture a contiguous group of stations from the target broadcast tower. Set scan rate of 500mS with trace mode set to 'erase/write'. Place marker on a center channel. Go up ladder and slowly rotate antenna while reluctant helper (wife) reads out dBm @ marker. Stop when highest figure obtained. Dismiss helper. Set freq span to entire UHF band; trace mode to 'max hold'. Wait for trace to stabilize at max values. Move marker to each peak and check if the frequency is a channel from the target broadcast tower. Record ( paper & pencil ) the dBm reading. Repeat from start with other broadcast tower.
Note: For each direction there was significant signal detected from the stations in the opposite direction. I'm not sure if this is off the back of the antenna or from multipath reflections. I do see ghost images with a large enough displacement that makes me believe it's reflections from distant objects.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
OTA Forum Sponsor
