Interesting info on speaker wire - Canadian TV, Computing and Home Theatre Forums
Old 2009-02-21, 07:55 AM   #1
Keith.B
Default Interesting info on speaker wire
http://www.roger-russell.com/wire/wire.htm
Keith.B is offline
Old 2009-02-21, 09:08 AM   #2
eljay
Premium Supporter
See also the Audioholics.com site for lots of info. on cables & interconnects, including:
- Rubbing the Snake Oil Out of Speaker Cables; and
- Top Ten Signs an Audio Cable Vendor is Selling You Snake Oil.
MY HT SET-UP (PICS & GEAR LIST)
eljay is offline
Old 2009-02-21, 03:47 PM   #3
dmoes
interesting article. I guess the lamp chord that I am using on my Paradigms is just fine but I knew that. A couple of years ago when I purchased a new AVR and just for fun I let the sales guy ramble on about the cables. were I to actually believe the guy I would have spent a fortune on new speaker and audio hookup wire not to mention the Power centre. when he was finished and thought he sold me his hill of beans I told him that the lamp chord, cables and power bar I have been using for years will be just fine I'll just take the reciever. I dont think he was so happy that I lead him on.
dmoes is offline
Old 2009-02-21, 09:19 PM   #4
PHAND
I am not sure which power centre you are referring to, but there are advantages to power conditioners when it comes to filtering.
I do agree about speaker wire. But I wouldn't pull someones house using lamp cord, mainly because it won't usually be rated for running inwall, have meter markers, rip cords, or colour coding. I am picky about my wire that I use in custom installations, but for those reasons.
CEDIA Certified CPI I
PHAND is offline
Old 2009-02-22, 12:57 AM   #5
nickleinonen
i've done blind tests between basic quality 12g copper speaker wire and fancy stupid expensive and i can hear a difference in the sound between the 2 of them. enough to justify the cost difference, no way ever..
i've done the same with video cables [component/rgb] and hdmi. again there are differences to be seen, but not enough to justify any extra costs [and i am happy with my $8 belkin hdmi's from factory direct]. the only place i would recommend any better cable is in hdmi when getting into long runs. i have done some work with 10m & 12m hdmi cables that were the basic ones that could not handle 1080p. but that is all i was given the ok to use [price restricted] that could now be fixed by using the cat5e/6 hdmi extenders that are more reasonably priced now.
nickleinonen is offline
Old 2009-02-22, 08:05 AM   #6
Keith.B
And that's a good thing!
Installation in walls and plenums is a different matter than just wiring up some speakers in the living room.
You wouldn't believe the specs of the cable we use for audio wiring on cruise ships
Keith.B is offline
