Connect a passive subwoofer to receivers powered output - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Consumer Electronics and Home Computing > Home Theatre Corner > A/V Receivers and Amplifiers
Old 2009-02-20, 11:34 PM   #1
btlsfan
Default Connect a passive subwoofer to receivers powered output
Hi,
My brother has been living with me for a month now and tonight he decided to hook up his HTIB speakers which contains a passive subwoofer to my old Sony receiver which only has a powered subwoofer output.
We found out that the Sony receiver only has a powered output so I thought if we take an RCA cable and connect it from the Sony receivers powered sub output and connect it to the HTIB receivers RCA input (red or white - tried both) we may be able to power the sub that way.
I thought we had it working because we did the auto calibration mic thing and my brother claims he heard the subwoofer rumble during the test yet when we tested it with my DVE disc and selected the LFE test there was no sound, same goes for dvds and tv.
Is it possible to hook up a passive sub to a powered sub output on the Sony receiver? OR do I have something wrong with the connections?
I saw an ad in the paper this week for powered sub for 249.99 which seems like a good deal so I may just buy him that if we cant connect a passive sub to the receiver.
CONNECTION: Sony Receiver Sub Out > HTIB RCA IN > Only Sub hooked up
Thanks to everyone for helping me in the past and hopefully with this question.
btlsfan is offline   Quick reply to this message
Old 2009-02-21, 12:40 AM   #2
Location: Toronto, Rogers, 9865 & 8300-eHDD, Panasonic TCP65S1, Denon AVR4310Ci; Sony KDL40W3000, 8300-eHDD
The method you used should work, although most subs on HTiBs are not great. Suggest you go for a dedicated amplified Sub. Make sure that the Sony AVR Sub option in the setup is "on" not "off".
57's Optimization Services (Home Theatre Optimization) . . . . 57's Home Theatre (Latest equipment & photos)
57 is offline   Quick reply to this message
Old 2009-02-21, 07:18 PM   #3
btlsfan
Thanks for your reply.
I fidlled with the settings and we now have it working.
Just a question about frequency settings for it - its set at 120 HZ now, what happens when I go up or down with HZ on the setting?
Old 2009-02-22, 12:34 AM   #4
That's the crossover where the frequencies go to the sub instead of to the other speakers (assuming that the setting in the AVR is set for sub only, instead of "both" and that the speakers are set to "small") It's usually best to set this about 20 Hz above the lower frequency spec for your other speakers.
Old 2009-02-23, 01:41 PM   #5
btlsfan
Hi 57,
Thanks for your replies on this and other posts.
This may be a stupid question but how do I find the frequency spec for the other 5 speakers?
I looked on the back but all I found was 6 ohm and 95 watts (there small).
EDIT: Found some info in the manual about the speakers and passive sub:
Satellite speakers: 6 ohm independence, Frequency Response: 160 - 20,000 HZ
Passive Sub: 8 ohm independence, Frequency Repose: 65 - 1,500 HZ
So does this mean I should set the cross over frequency to 40 HZ?
Old 2009-02-23, 01:45 PM   #6
If the speakers came with an operating or setup manual, the specs could be there, or you could search the web for your make/model of speakers. Small speakers would have a frequency response of say 100-20 kHz, so you'd set the crossover to say 120...
Old 2009-02-23, 01:50 PM   #7
btlsfan
Shoot, I am not sure if you saw I updates my post I added:
Which I got from the manual, so I suppose I should set the crossover to 180?
Old 2009-02-23, 02:00 PM   #8
Try 180, those must be some pretty small speakers alright...
Old 2009-02-23, 02:09 PM   #9
btlsfan
HAHA... they are he said he payed 199.99 for them a few years ago there about 4.5 inch's high and 3 wide.
Old 2009-02-25, 12:22 AM   #10
Wharfe
Are you getting any sound out of the sub??
If I am understanding this correctly, there's no way this can work.
A passive subwoofer NEEDS an amplifier to power it. The powered sub output on the receiver is very low power, because it's supposed to be connected to an amplifier which will take the signal and boost it. If you're just taking that very low power signal with no amplification and hooking it to an unpowered/passive sub, there's simply no power coming from anywhere to drive the sub.. it can't work.
Sorry if I read the post wrong, but if I understand what you're asking then my post is correct.
Wharfe is offline   Quick reply to this message
Old 2009-02-25, 12:45 AM   #11
If you read post 3, you'll see that it is working. He's using the HTiB as the amp for the sub.
Old 2009-02-25, 12:51 AM   #12
Wharfe
Thank you for clarifying! I was reading the line "CONNECTION: Sony Receiver Sub Out > HTIB RCA IN > Only Sub hooked up" and couldn't make sense of it, but now I understand completely. I didn't realize the HTiB amp was being used..
Sorry to interfere.. just ignore me :P
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
