nüMaps Lifetime map updates from Garmin - Page 4 - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Consumer Electronics and Home Computing > Portable Electronics: Digital Cameras, Camcorders, ebook Readers, iPods, MP3 Players and GPS
Old 2011-12-22, 08:06 AM   #46
scotta
With regards to using a "relatively small" (e.g. 2G) card:
Originally Posted by Gino Cerullo View Post
No! Your nüvi probably already has 2GB of storage, and you're approaching that limit already, and maps make up about 85%–90% of what is stored on your device.
This assumes that you want to move the entire map from the internal storage to a card. As I've already mentioned, you can split a map between internal storage and a card. In this case, a low capacity card may be sufficient to hold the "overflow". I'm currently using a 1G card.
However, the cost of cards is quite low these days, so paying the extra for a larger card may be worth it for future-proofing.
scotta is offline
Old 2011-12-22, 08:09 AM   #47
lightbender
" Since the cards use the FAT32 file system I would suggest a 4 GB card and no bigger since the FAT32 file system has a 4 GB file size limit anyway. "
I don't think its limited to 4 GB, Garmin's FAQ says up to 16 GB. I'm using a 16 GB card where I have stored 2 additional maps, plus music with no problems whatsoever. Also, I'm way past 4 gigs on the card.
edit: did some research, and a FAT32 file system can hold up to 2 or 16 TB depending on the sector size. However, as Gino points out a single file (e.g. map) can be a maximum of 4 GB, so if you are only storing a single map, 4 GB card is the maximum you need. If you want to store more than one map, music, etc, it may be worth it to get bigger.
lightbender is offline
