#181 |
I did not know if the DPP44 was being used or not. I guess thats why I posted in the first place. I really do not want them to run a second line as they will have to drill up through my floor. I guess I will wait and get the install done after Oct 23rd.
#182 | |
#183 |
Just spoke with Bell technical supervisor and he informed me that they have no plans at this time to start using the DPP44 on Oct 23. I guess I will have to buy it myself or run the second cable.
#184 |
Asking someone within Bell that question is never a good idea. 90% of them would not know the difference between a DPP44 and an SW44 anyway, let alone if and when Bell will be using them.
If they are being made available to Technicians on Oct 23rd (and I have no reason to doubt JoeLouie), it does NOT mean that every Tech in Canada will have them in their Vehicles on Oct 24th...... @ m3repair. I hope they NEVER go for the DPP33, I speak with countless bell Techs and suppliers and the return rate on this product when used for Bell TV, is very high. One supplier said as high as 50% are being returned because they cannot get 82 on them. He is in the States and tests them on Dish and they work just perfectly, so I can only guess it is an omission in the Software on the Bell Receivers. |
#185 |
Update, just spoke with a Sky-tec Installer who does alot of Bell installs and he informed me that in my case they will be installing a DPP Quad LNB which is capable of running 4 recievers. They can all be PVR's or non PVR's any combination of both.
I guess I dont need an DPP44 afterall. This equipment he said will be available on the 24th (my install date) along with the DPP44 so I guess you were right. I also mentioned that I may be expanding my system next year. He then told me that I will need a DPP44 at that time which will allow me to go to 6 recievers. |
#186 |
There is much more accurate information shared on this superb Forum than 100 phone calls to Bell.....lol
#187 |
You can get the same information from Bell, you just have to wait an extra few weeks for them to actually confirm the "rumours" that we already know are true lol
#188 |
in Alberta (Edmonton) dpp quads will be available from the fist week of November. As well as dpp44 switches.
#189 |
It was supposed to be available October 23rd (tomorrow), but I know that Bell didn't send nearly enough to us (and probably the rest of the country, so we won't have them tomorrow. Not sure exactly when we'll get them at this point.
#190 |
None in the several warehouse's I spoke with yesterday, oh well.....
#191 |
I have a question for the bell techs on here.
I had Bell TV reinstalled at my new house on a move order. The tech installed the dish on the side of my house (talked me into it, as I had preferred it on the roof). The issue I have is that my new house has yet to be stucco'd and my builder has told me that if the dish is reinstalled after it is stucco'd there may be issues with warranty if I ever had problems with moisture getting under the stucco. Does anyone know if I contacted Bell would they come reinstall my dish and put it on the roof (where I originally wanted it) under the install warranty? I think the install warranty is 90 days? Or would they charge me for install again...and if so, how much would I be looking at? Thanks. |
