Well, I just finished painting my home theatre room (the colour my spouse wanted, so she's happy) and it looks great. Moved everything back and sat down to relax.
Since I had cleaned all my connections a few months back (routine maintenance and cleaning) I didn't do it this time, but I saw some weird almost horizontal lines on my composite video connection. S-Video and component were fine. Checked everything, but still those weird lines (almost like looking through a fence with horizontal cabling only, except they tilted up at the right a bit - never saw anything like it - lines about 1" appart. Well, eventually I disconnected the composite cable from the receiver and from the TV, cleaned the connectors, reinserted it and everything was fine again. I can only assume that moving the TV had "weakened" the connection slightly (I'm using a good quality cable). Oh well, at least it turned out OK. I guess I should have used the opportunity to clean those connections after all... So, if you've ever noticed a problem after moving your equipment, check and clean those connections. There are lots of times people report problems on this forum due to poor cable/connections...
I concur , I had the horizontal incident exactly as you stated it , the solution , as prescribed.
I'm sounding like an MD :-? |
I would think this is more than likely a bad cable or connector than a dirt or oxidation issue.
