PS3 Media Server - Tversity Killer? - Page 2 - Canadian TV, Computing and Home Theatre Forums
Old 2009-01-27, 10:09 AM   #16
supergenius
Originally Posted by cwagner View Post
Is it only my or is the PS3MediaServer slooooow?
I find it much faster than Tversity and I'm running it on a slower PC. Do you have the latest jre installed?
supergenius is offline
Old 2009-01-27, 10:13 AM   #17
TKG26
i found it fast, i use a HP quadcore 6600 with a dir655 dlink
Licenced HVAC TECH: "Without seeing your problem i can only offer suggestions, no warranty is included with my advice"
TKG26 is online now
Old 2009-01-27, 10:55 AM   #18
testikoff
Originally Posted by nmaf View Post
streaming IF you have enough CPU power... "Actually a Core2Duo CPU is enough to transcode 1080p with default network or quality settings, but a P4 is the very low limit in order to play a 720p video."
i have found 1080p struggles on 100mbps connection, so i hafta get a cat6 cable to run gigabit ethernet, and ill let you know how that works.
Gigabit? Most of the MKV 1080p encodes use <20Mbit/s bitrate. My 100Mb connection works without a hitch...
testikoff is offline
Old 2009-01-27, 02:04 PM   #19
profets
like testikoff mentioned, i stream 1080p over a 100Mbps connection all the time.. those 1080p videos are usually around 15Mbps.
also, you can use cat5e to make a gigabit ethernet connection if its already in place
profets is offline
Old 2009-01-27, 06:55 PM   #20
nmaf
Originally Posted by asif9t9 View Post
Wow, I never knew the PS3 had a gigabit ethernet connection.
yeah. i'm not a ****** or anything, and i really don't use this thing for gaming, but you gotta admit, the ps3 is one fancy piece of machinery. and people complained when it cost 700 bucks, for what it did... wireless/gigabit ethernet, blu-ray, sacd, card reader, 60gb hd, bluetooth, etc, etc, etc, it was a pretty good deal.
as far as the program goes, i bought a cat6, and just streamed some 1080p flawlessly. with the exception of a cable running down the side of the stairs, this is awesome. very, very happy with this program.
nmaf is offline
Old 2009-01-27, 07:42 PM   #21
Richard Travale
Location: Vancouver Island. Shaw cable.Sony 46V2500,DCT6416(w/TB Xpndr), PS3, Denon AVR2807, Paradigm spkrs.
Is there a way to over-ride the 8 sub-folder max that is in place?
I have my mp3 library buried just a bit deeper than that and would sure like to get the streaming audio.
p.s. I'm not sure if this is a PS3 thing or if it's a PS3 media server thing.
Richard Travale is offline
Old 2009-01-27, 11:37 PM   #22
w3aponx
Not sure about your specific question, but you might have an easy way around it. PS3MediaServer by default shows your entire disk from the very top, and some people like that, however it is always possible to provide a list of directories to show instead (including sub-directories, of course). This is especially useful when some of your users do not know or care what your entire disk structure looks like, you can bring them directly to the good stuff.
w3aponx is offline
Old 2009-01-27, 11:40 PM   #23
Tezster
I find that the audio and video are often out of sync when transcoding video - has anyone else experienced this issue?
Tezster is offline
Old 2009-01-27, 11:53 PM   #24
Deeival
The 8 sub-folder thing is a PS3 limitation. So there is no way around it.
Deeival is offline
Old 2009-01-28, 02:18 AM   #25
Richard Travale
Thank you, that has solved my problem.
Old 2009-01-28, 08:39 AM   #26
sleemo
I use TVersity and convert my MKV files to MPG using MKV2VOB. Is there a picture quality difference when streaming straight MKVs using PS3 Media Sever?
sleemo is offline
Old 2009-01-28, 10:52 AM   #27
supergenius
Shouldn't be any difference if you use tsMuxer as the engine. tsMuxer basically does the same thing as MKV2VOB but on the fly.
Old 2009-01-29, 12:01 PM   #28
wm_cheng
So it can read VOB files straight from the VideoTS folder, but someone has mentioned that it can't read the menus, so no access to chapters or special features? How do you select the different audio features?
What about the multiple VOB files, will it play the movie in its entirety or does it skip from VOB to VOB with a slight pause, or does it require you to select the next VOB once the original one is finished?
Thanks,
Panasonic PT-AE2000U|Elite Cinetension2 100"|Yamaha RX-V3900|PS3|Paradigm Monitor 7|Bose AM-10s|Polk PSW350
wm_cheng is offline
Old 2009-01-31, 09:58 AM   #29
OddyOh
Thumbs up great on a mac
Agreed, this thing rocks. I've got it running on our two iMacs over gigabit. I don't seem to have enough jam to transcode mkv's on the fly, but oh well, I run tsmuxergui under Crossover for Mac. PS3MediaServer is worth using for the lack of dropped connections alone, unlike other "paid" solutions.
I've only been using it for a couple weeks, and it kills Nullriver's MediaLink and Mediatomb (the latter I had compiled myself due to lack of a proper Mac version).
I used to be almost jealous of the Windows software available for this purpose, but no more.
OddyOh is offline
Old 2009-02-01, 08:34 PM   #30
QuickSilver
Nice piece of software. Will not work with my G5 for MKV files and barely with my Core Duo Macbook 512mb of ram. I guess I need to upgrade my Apple machines to take advantage of my new PS3.
QuickSilver is offline
