#76 |
Probably and most likely. But I dont like to assume that without looking at Channel Masters schematic of it. Its pretty easily to distort by changing a value or bending a coil. I know I can screw up a uhf tuner almost by looking at it, heh.
My CM0264 uses the BFG198 NPN 8Ghz wideband transistor. The example schematic in the data sheet for the BFG198 does show a 75 ohm input and output impedance being used.
#77 | |
of the road given the street price. SMD placement and assembly seems a little rough. The mechanical design of the housing leaves much to be desired for a unit intended to be mast mounted IMHO as it isn't sealed and water can easily enter the housing perimeter via capillary action, pooling in the case bottom. I'd expect to at least find a conformal coating on the PCB with such a housing design. That aside the actual circuit design is better than most in this class with the claimed performance actually supported by the component data sheets. I derived a preliminary schematic after identifying the active devices. Note the FM trap only functions for the discrete VHF input and not for the combined UHF-VHF input. Also it appears additional reduction of the UHF noise figure is possible given the bias of the BFG67 in the existing design. I'd be happy to share the schematic with folks here however either I lack the requisite forum superpowers to attach a file or doing so isn't supported. |
#78 | ||
#79 | |||
monolithic FM band trap, namely a 10T hand tuned inductor which is part of a user tunable tank. Quote:
unit as a UHF-only amp I'd be tempted to remove the choke supplying power to the BFC198 to quiesce the VHF section and further reduce overall noise. |
#80 |
Another improvement they could make to the 0264 model, would be to include band-pass filters on each of the UHF and VHF paths, before combining the two signals. Preferably after the individual pre-amps.
My experiments with it here indicate that they don't do that, and as a result the VHF and UHF antennas have to point in the same direction to avoid interfering with each other in the pre-amp. Cheers |
#81 |
I'd already attempted doing so. The supported JPEG
resolution renders it illegible. I've placed a copy below. You'll need to manually construct the URL due to my being under the magic 10 post threshold and as advertised the robotic censor will likely filter it: freepdfhosting (dot) com (slash) f93234fe16 (dot) pdf Note this is preliminary. Determination of the smd capacitor and inductor values left as an exercise for the truly curious. Last edited by stampeder; 2009-02-11 at 01:12 AM. Reason: Folks, copy this to your browser: http://freepdfhosting.com/f93234fe16.pdf |
#82 | ||
bandpass filtering. Combination occurs after post bandpass. Quote:
The UHF section is designed to be capable of both UHF+VHF amplification. So if you are receiving any unintentional VHF signal from a UHF antenna this could cause your issue. |
#83 | |
Got it, thanks. Looks very nice.
Where are the BFG540 and BFG67 hidden in the preamp ? When I looked at mine, all I could find was the BFG198, which the datasheet I have has a chart plotting its gain from about 30mhz to over 1ghz. Quote:
#84 | ||
If you casually viewed the board you probably mistook them for passive components. I use a jeweler's loupe when dissecting an assembly of this size. Note the diagram reflects the components found on the particular 0265 unit at hand with the following SMD codes: CODE MFG DEVICE PACKAGE -------------------------------------------------- V3p NXP BFG67 SOT143 N37 NXP BFG540 SOT143 p5C PHIL PMBD7000 SOT23 BFG198 NXP BFG198 SOT223 Quote:
numbers met the device data -- which in this case does seem reasonable. The BFG67 measured collector current is ~17.8ma which seems rather high given where NXP characterizes the device. It appears a reduction of 0.5db in NF is possible by reducing Ic to 5ma. Unsure ATM how this will impact maximum output level from the BFG540. |
#85 | |
#86 | |
Brian |
#87 | |
in the OTA broadcast market outside of the magic antenna crap stuffing the shelves of the local MalWart. So we're probably lucky to have the currently available selection. Don't be too put off by the vintage of the components in the preamp under discussion. The engineering challenge of economical fringe VHF/UHF signal reception was a done deal way before these devices were even thunk up. That said the Avago ATF-551M4 (or sibling device) with which I hazard GerryB was experimenting, looks to have the potential to consume a few weekends of hacking. That's quite impressive performance at a piddling price. Guess those are the bread crumbs which fall off the table where folks are trying to solve the same issues at 5.8GHz. |
#88 | |
Im not ragging on the unit, it works very very well. Compared to my old Radio Shack preamp its like night and day. I do have pictures of the RS cut apart, posted in the preamp thread, if you want to get a good laugh.
#89 | |
Brian |
#90 | |
