Baluns (Brands, Designs, Losses, DIY Loops, etc.) - Page 50 - Canadian TV, Computing and Home Theatre Forums
Old 2012-03-26, 10:23 PM   #736
otadtvman
Default Wendell R. Breland's suggestions
Wendell R. Breland has another suggestion for an outdoor balun:
Originally Posted by Wendell R. Breland
Not for me. The Winegard TV-2900 balun uses twinlead for the 300Ω side so yo do not need to be concerned with wire spacing. It is also weather proof. MCM has a very similar product, part number is 33-040.
In low signal level conditions I prefer to use a λ/2 Coaxial Balun (that I constructed).
  1. Has anyone recently tested the Winegard TV-2900 or MCM part #33-040?
  2. Has anyone constructed their own Breland outdoor balun?
  3. Using this design, how many inches (or mm) of Belden 1694A would be necessary for channels 7 to 51 such as with a Mclapp M4?
otadtvman is offline
Old 2012-03-27, 08:27 AM   #737
ProjectSHO89
See post immediately above...
ProjectSHO89 is offline
Old 2012-03-28, 02:30 PM   #738
roger1818
I am looking at building a coax balun for channel 6 and found some interesting resources. First of all I found a 4:1 coax balun calculator that allows you to enter the desired frequency (85MHz in my case) and the Velocity Factor of the coax (assuming 0.66) and it will calculate the Half Lambda Coax Loop Length (45.8"). I will recalculate when I know the Velocity Factor of the coax I will be using.
4:1 coax balun design
Secondly I found a picture of a nice looking build technique. They don't look weather proof, but would be fine for my attic install (see the two on the right):
roger1818 is offline
Old 2012-03-30, 11:39 AM   #739
otadtvman
ProjectSHO89,
Thanks for alerting me to ADTech's test results.
Old 2012-03-30, 11:53 AM   #740
otadtvman
roger1818,
Thanks for the balun caculator link & build technique photo - looks good. Was there also a close-up of the soldered connections? Weather proof: One could use a RS ABS enclosure as suggested by Wendell.
Is this balun technique appropriate for a channel 7-51 Mclapp M4?
Old 2012-03-30, 01:28 PM   #741
ADTech
Half wave (coax) baluns have a very narrow frequency band in which they are efficient. They are best reserved for single-channel antennas.
Broadband ferrite core baluns such as I tested are the best compromise (generally) available for a wide range of frequencies in a single device.
ADTech is offline
Old 2012-03-30, 02:19 PM   #742
stampeder
ADTech is precisely correct - use the right tool for the right job.
Also just a point to readers: a separate new baluns thread that was only a day or two old was merged into this existing one. If you've just joined in here in this thread please be aware that there is already a huge gold mine of info on baluns in this thread, so it is well worth the time to read through it for the best answers to your questions.
stampeder is offline
Old 2012-03-30, 06:19 PM   #743
nezdepain
My coax baluns (cut for 521 MHz) work well on the entire UHF band for local signals and for more distant channels. They also perform well in the VHF band for local channels. I did some testing on a 50 miles distant VHF channel with fair results. The difference I could measure with my tuner, compared to a channel master balun, was maybe around 10% for that VHF channel. I would have to reconfirm this with more testings, but in any case, I don't consider their useful bandwidth range limited to a few channels.
nezdepain is offline
Old 2012-03-30, 09:50 PM   #744
roger1818
No, those are pictures for baluns you can buy and they aren't trying to show how to make them.
As ADTech said, they are best for specific channels. You might be able to get away with it in UHF only, where the wavelengths aren't as far apart (on a logarithmic scale) if your weak channels are near the centre of the band (or don't care about channels at the far end of the band). Similarly, you might be able to make one for a weak central VHF-HI station that will work with other VHF-HI stations, but it will likely only work for one or two VHF-LO channels.
Old 2012-03-30, 10:52 PM   #745
ppauper
I emailed that particular company a few years back, and they no longer sell those baluns
ppauper is offline
Old 2012-03-31, 12:36 PM   #746
otadtvman
Of all the broadband ferrite core baluns you tested, which one would be most appropriate for a ch 7-51 Mclapp M4? Thank you.
Old 2012-04-02, 11:19 PM   #747
holl_ands
K6STI calculated loss of under 0.12 dB in a half-wave Coax Balun across FM Band:
http://ham-radio.com/k6sti/balun.htm
There are equivalent calculations for two 4:1 configurations in UHF Band in this thread:
Under 0.5 & 1.0 dB: http://www.digitalhome.ca/forum/showthread.php?p=874362
holl_ands is offline
Old 2012-04-04, 04:17 PM   #748
pfm1
Default Simple air core balun ok as 4:1 TV antenna transformer ?
Typical commercial tv baluns are wound on some sort of a core material, most likely ferrite. But what I am trying to figure out is why not just a simple air core ? For a wideband uhf coil application do you think permeability is much to sweat about ? Because permeability is all about being able to wind less turns to get more inductance and I guess you don’t really need that much inductance at uhf. Plus using ferrite is a matter of matching the material with the frequencies it is used for otherwise core losses (u’ and u’’) at those frequencies could actually defeat the purpose of the core.
For the primary a few (10?12?) tightly wound turns in half to one c.m. coil diameter should be good I guess. The secondary can be 3 turns interleaved with the primary winding across its length.
Has anyone ever tried an air core balun for a 300:75 transformer like that ? Would this work ? If not can anyone please explain me why ?
Thanks.
Last edited by stampeder; 2012-04-05 at 02:15 AM. Reason: Yep, this is the correct thread :)
pfm1 is offline
Old 2012-04-04, 04:30 PM   #749
Xauto
pfm1: Yes it will work. If you read #735 of this thread. That is what I did, but the turns need to be 2:1 not 4:1.
Note this is not a true balun. It is more like a 1/4 wave length matching section. Two 1/4 wave length sections can be combined to make
a balanced transforming unit.
Xauto is offline
Old 2012-04-04, 05:19 PM   #750
pfm1
yes and I was referring more to a "transformer", as in inductive coupling with no core involved.
btw, can you tell anything about the bandwidth of that balun ? how wide or narrow might it be ?
pfm1 is offline
OTA Forum Sponsor
