#211 |
300ohms,
Is it worth to browse the fleamarkets to try to find one made in Japan ? Or if this did give me better results, then it is not worth it? Intravino |
#212 | |
Today, I picked up an antique, never been used, clay Scottish pipe for $3. A new pipe in the tobacco store is a minimum of $20, and I needed another anyway, heh. I also got well over $1000 worth of SLR camera lenses, in pristine condition, for my son for $42, heh.
#213 |
I like fleamarkets too.
I guess now, I will search for the perfect balum. Maybe I try to make one. |
#214 | |
#215 |
#216 |
in reference to the japanese baluns a couple of people mentioned, are these discontinued or are the japanese still making them (so presumably in this internet age they could be ordered from japan ?)
#217 |
Good point, I dont know. A lot of the old Japanese manufacturing stuff is sold off to Taiwan and China and others, and the Japanese smartly move on to newer and more profitable endeavors. I noticed that on their blank optical disk manufacturing. The good TY blank CDs and DVDs are now pretty scarce.
#218 |
Gah. This whole thing is too addicting. Now I'm thinking of replacing the balun in my antenna, because I think the one I bought at home depot might be hampering my signal. (Phillips outdoor model)
#219 |
How does the Philipps outdoor compare with the CM 3075 balun...
#220 | |
According to the links posted earlier, the Philips balun does not compare well.
#221 |
Wait a minute, there was another analysis done where the Phillips balun was very close to the CM one. I think the moral may be, it depends on the individual unit. The CM one may have better quality control at the factory.
#222 |
I bought a Source balun, not sure of the name...but I guess the best bet is the CM.
#223 |
More than likely, but dont throw the other away. Test and compare it to the CM one.
#224 |
I'm really lamenting the fact that none of the pre-amps that I can find have 300 ohm inputs. I found the circuit layout for one in a 1977 IEEE Transactions on Broadcasting
(Advanced Antenna Design and an Ultralow-Noise Preamplifier Extend UHF Viewing Area : ieeexplore.ieee.org/iel5/11/4044035/04044041.pdf but you need an IEEE account or access to an institution that has one... Thanks, local college!) But that is beyond my current insanity level here. |
#225 |
firimari:
What's the basis for your statement that the balun might be hampering your signal - are you experiencing reception difficulties????cause now you have me doubting... |
