Home Alarm Battery needs replacing... - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Consumer Electronics and Home Computing > Home Automation and Security
Old 2009-01-21, 11:03 PM   #1
mapleyther
Default Home Alarm Battery needs replacing...
Hi
I have an alarm system for which the battery needs replacing. I have been quoted an exorbitant price by a subcontractor of the monitoring company, for what I suspect will be 5 mins work ($160 including call out charge and labour). Is there a way to do this myself or at least find a cheaper option?
I live in Toronto.
martin
mapleyther is offline
Old 2009-01-21, 11:09 PM   #2
e268
I replaced mine once. Take a look at your user manual and see what voltage the battery is, or look at the actual battery itself, and see what voltage it has. Go to The Source web site where they used to have these battery (sealed lead acid). It would be about $20. You just pull the old one out and put the new one in.
Yammy RXV2400 & CDC815, Celestion DL8 fr Mission 73Ci ctr Sansui rear Velodyne CHT8, Vaio TT180, i7-920@3.8Ghz
e268 is offline
Old 2009-01-21, 11:48 PM   #3
Dog Byte
Interstate Batteries sells more than auto batteries and they have a Web site too. A typical 12V lead acid alarm battery is around $20.
Dog Byte is offline
Old 2009-01-22, 12:24 AM   #4
99semaj
Odds are that it's a 12V 4Ah gel cell. You're best bet it to simply disconnect it by pulling the leads off (won't hurt the alarm panel) and taking it into a place like Interstate. They will likely also dispose of the old one for you.
Like others said, $20 should be an easy price to find. Anyone with any buying power at all (i.e. 20 foot containers at a time) can make a handsome margin at that price.
99semaj is offline
Old 2009-01-22, 01:02 AM   #5
Crosstown Battery in Toronto is another inexpensive source of batteries. 21 Musgrave St. (416) 691-2712. They recycle.
57 is offline
Old 2009-01-22, 07:44 AM   #6
PlaceHolder
Co-worker once told me about a similar story. Alarm company wanted too much for a simple replacement... but they actually told him he could do it himself much cheaper. I believe he said he found a replacement battery at Home Depot (but we live in a small town, so few options... TO should have many other options.) He said it was a very easy replacement... but didn't mention how he disposed of the old battery.
PlaceHolder is offline
Old 2009-01-22, 08:30 AM   #7
rosenqui
I get mine at Total Battery in Ottawa. Just disconnect your old one and take it with you to a specialty shop like that; they'll almost certainly have a match in stock.
Ditto for most user-replaceable UPS batteries - they're much the same as alarm batteries.
rosenqui is online now
Old 2009-01-22, 10:44 AM   #8
TECHNOKID
One thing you have to do is make sure you let the monitoring company you are doing this. Some panel have tamper switch and as soon as you open the panel, it will go to alarm. Acquire your battery first and as you mentioned it takes approx. 5 mins to do.
TECHNOKID is offline
Old 2009-01-22, 11:32 AM   #9
JohnnyG
I was specifically told that I could NOT do it myself as it would invalidate my monitoring contract! This was with ADT.
Naturally, I went to BEAM vacuum dealer in Mississauga that also sold DSC alarm systems and bought and installed the battery myself. 5 minutes work and a fraction of the price. ADT was none the wiser.
JohnnyG is offline
Old 2009-01-22, 11:45 AM   #10
Larry
When faced with a similar situation, I decided to look at changing to a new alarm company. I found one that would change all the equipment in my home for less than I was quoted to change the battery, and the monthly monitoring would be less to.
I then call my current alarm company to cancel my service - they offered to change my battery for free, and lowered my monthly fee.
Worth a shot.
Larry is offline
Old 2009-01-22, 11:58 AM   #11
JohnnyG
Nicely done, Larry! Only problem is, the battery in these things seems to have a habit of failing right in the middle of a service contract period!
JohnnyG is offline
Old 2009-01-22, 12:16 PM   #12
greenhome
If you are going down the route of changing the system, go to a new sub division and get some #'s (i.e. off a lamp post). They are usually quite aggressive with pricing and are flexible on the monitoring fees. (often cheaper than what you might be paying now)
greenhome is offline
Old 2009-01-22, 04:01 PM   #13
kcolero
Maybe this should be obvious, but don't you need a key (which I don't believe that I have) to open an alarm panel to access the battery?
kcolero is offline
Old 2009-01-22, 04:06 PM   #14
Rouge21
Location: Vinegar Hill, Rogers, Sony KDS50A2000, Samsung LNT4061, SA8300, PS3, TT GO730
Our alarm panel (monitored system) is in our front hall closet behind some coats. The cover is secured by a couple of screws.
Rouge21 is offline
Old 2009-01-22, 06:32 PM   #15
notsure
My alarm company pays for the batteries.
I bought the system outright, they installed it, I pay a monthly fee for service (~$11 or $12 I think) and they pay for any needed repairs/battery changes.
I really can't complain at all.
notsure is online now
