Bell TV 9241 HD PVR discussion thread - Page 56 - Canadian TV, Computing and Home Theatre Forums
Old 2010-03-10, 01:45 PM   #826
redgrandam
I think so, same as before. I don't have a recorder, so I haven't done it, but have used them before.
Then only issue you could have is copyright, but I think that only affects things with HDMI.
Hook it up and give it a try! the 9241 came with RGB cables...
redgrandam is offline
Old 2010-03-10, 03:28 PM   #827
scrubby
I record programs on my SD DVD recorder from the 9241 through the composite (Y-W-R) connection with no problems at all.
scrubby is offline
Old 2010-03-10, 06:20 PM   #828
julie_rose_
not me doesn't work. Can Include a picture of the behind of my receiver? if i can i'll do it tomorrow.
julie_rose_ is offline
Old 2010-03-10, 06:55 PM   #829
Pinza
As other have said, you need to use the Red/White Yellow connections on the 9241 these are SD 480 outputs, then make sure you connect to the INPUT on the DVD Recorder.
I have a DVD recorder hooked up to my 9242 works like a charm.
You can only record SD of course.
Pinza is online now
Old 2010-03-10, 07:42 PM   #830
julie_rose_
My red/white/yellow connections are plugs. I try to plug my connection with red/blue/green connection and still not working. Those second connection red, blue, green where it need to be plug in, dvd + tv or dvd+receiver? I have a sd tv by the way.
Old 2010-03-10, 07:51 PM   #831
Pinza
Ah, you are using the 9241 on an SD TV.?
Then you will need to get some kind of switch to connect from the Red/White/Yellow that will give you 2 sets of Red/White/Yellow ports, 1 for the TV 1 for the DVD Recorder.
The Component Red/Blue/Green is an HD output and will not be compatible with the inputs of the DVD Recorder.
Pinza is online now
Old 2010-03-10, 07:53 PM   #832
julie_rose_
yes i am using a 9241 on a sd tv? Funny, its not hd my tv but the color is clear. I record a lots so that is why i ask for a hd-pvr(200 hours). so i need another set of red/white/yellow ports. the second set, do i plug it through my dvd+receiver?
Because the first set is plus from my tv and dvd.
Old 2010-03-11, 09:37 AM   #833
scrubby
You can buy RCA plug splitters (you will need 3) to divide the Y-W-R output from the 9241. One set will go to your DVD recorder and the other set will go to your tv.
These are readily available at electronics stores.
scrubby is offline
Old 2010-03-11, 11:42 AM   #834
dsslearn
Unless you are archiving to view elsewhere, I would suggest an external hard drive connected to the 9241. Works great.
dsslearn is offline
Old 2010-03-11, 05:26 PM   #835
FunkyTown
I don't believe there are green, blue, and red inputs on a SD DVD recorder. DVDs are not high def. Therefore the component inputs are not going to be found. The next best quality is s-video. However, the 9241 does not have s-video out. So you are left with composite - the yellow video cable and the red/white audio. This is why the 9241 sucks compared to the 9242.
FunkyTown is online now
Old 2010-03-11, 05:51 PM   #836
Stan Dev
Just one of several reasons.
Stan Dev is offline
Old 2010-03-11, 06:46 PM   #837
julie_rose_
when i moved to the other room in my house, i will ask someone to install the cable and also plug my dvd so it could work. thanks for all your help very appreciated.
Old 2010-03-11, 08:14 PM   #838
Overburn
What a pile of crap this box is, what are the chances that if Bell sends me a new one that it wont give me the same issues?
Damn thing keeps freezing! Im missing chunks of my recordings... ugh so frustrating.
Overburn is offline
Old 2010-03-12, 02:42 PM   #839
yonder
The 9241 does have S-video out. I use it to connect to a Pioneer 550 HDD/DVDR.
yonder is offline
Old 2010-03-12, 11:41 PM   #840
redgrandam
Are you using HDMI? If so try changing to component, and unplug the HDMI from the receiver (don't leave it plugged in not connected to anything on the other end), see if that helps the freezing. I had HDMI on my old one that was freezing allll the time, got a new one, same thing, got a third one, hooked it up with RGB, and it's been fine (aside from the ongoing audio problems). However, I haven't had time to connect this one with HDMI for a bit to see what it does.... but might have helped.
Tags
9241, bell tv, belltv, hdcp, hdmi issue, ppv, pvr, recording
