#31 |
Just picked up a 9241 this past weekend, love it. No real complaints but did notice one quirk.
I'll be PVR'ing a show and watch the show a few minutes delayed. I'll try and skip through the commercials quickly (30-seconds forward) and the odd time the picture will freeze and the PVR isn't responsive. It'll eventually "unstick" itself after maybe 5-10 seconds. I'll continue to watch then notice that the 5-10 seconds where the PVR was stuck, the same 5-10 seconds is missing from the show. I'm guessing when the PVR was stuck, it's not recording the show also. I think I seen the same thing when I was watching a recorded show also but need to confirm this. Anybody see this issue? |
#32 |
I just got a new 9241 hooked up. I'm having trouble with the digital audio output (toslink). I used the cable that was hooked up to my PS3 and had no issues. I double checked the cable again using the PS3 and it was fine as well. The receiver doesn't show the signal dropping in and out so I don't think there's any connection issue. My problem is that the sound is ok for a couple minutes, then will constantly "pop" and it sounds horrible like its going in and out. Once in a while the sound will come back in, then continue its problems and continue the cycle. Is my receiver a dud?
#33 |
I've noticed the same issue as you Tanner but I chalk it down to a buggy initial software release. IIRC both the 9200 and 9242 had similar quirks about the recording when they first came out, which were fixed by later firmware upgrades.
#34 |
Thanks Gimli, ruling out hardware issue since you experienced the same thing. Hopefully a future firmware will address this.
#35 |
Tanner,
I have also noticed the same issue on my new 9241. I experienced it trying to replay something during the Superbowl so you can imagine the reaction I had from all of the guests when the game froze. I had a 9242 that broke and was replaced with this 9241. I never had that issue come up with the 9242 so I'm hoping this is just a software issue. |
#36 |
Is anyone able to record an existing program after it's already started, then tune into a second program while the first is recording? For some reason, my receiver isn't allowing me to do this. I get error 324 - recording in progress. I can however successfully record 2 future events simoultaneously.
#37 |
I also experience the freeze once in a while, usually when pressing the skip button repeatedly. Just have to let it sit for a bit and it comes back, which is a pain because I was skipping so I wouldn't have to wait...
#38 |
I've been using my 9241 for a week now, and I have some observations:
1) Like Tanner and others have reported, the 9241 will occasionally freeze for anywhere from several seconds to a minute or more. Once or twice my 9241 froze long enough that I had to power it off then on to bring it back to life. Hopefully a software update will fix this. 2) One of my scheduled recordings on a HD channel did not work. The scheduled timer reported "signal loss detected", which is strange since the sky was clear and cloudless at the time. ![]() 3) This may be a cabling issue, but I've noticed that the 9241's "up converting" of SD programming to HD output leaves something to be desired. There is a slight but noticeable degradation of picture quality from the HD component output verses the same programming on S-video. I have new cables on order, so we'll see if that makes a difference. 4) The HD video from HD channels is very impressive. No complaints there! Paul |
#39 |
These 9241's are certainly a little odd to say the least.
Just played with and activated 7 of them this morning, all acted the same; Signal level was in low 60%, straight from the Box. All showed DP equipment in Check Switch Screen. All showed 119 Sat in Point Dish Screen, with Bell 91 showing wrong Sat. All of them had Remotes that would NOT work the receivers, all needed new address's. All were pretty slow to respond to any Remote functions. After downloading firmware, Signal level jumped to low 90's. Most took 3 or more Check Switch to show the actual switch's installed. Only 1 worked as I would expect as soon as it was downloaded. I hope this was just an odd batch, this would be so frustrating for an installer, day after day. |
#40 |
I have a brand new 9241 PVR - - the old style outputs (Video-Left-Right) of which I have modulated in our family room where the PVR is located onto a Channel 3 RF carrier for delivery to our bedroom TV upstairs via cable.
To my surprise and disappointment, the silver remote we have been using with our now retired Model 5900 WILL control the Model 9241 via infrared but can't be used in our bedroom because the UHF RF side is not communicating with the new PVR. I figure it must be an RF channelization issue - i.e. the 9241 is "listening" on a UHF channel other than the one used by the 5900. Is there any way to positively diagnose if my hunch is right and more importantly does anyone now a hack or whatever that would enable me to get the 5900's remote talking via UHF to the new PVR ? |
#41 | |
From the info window on the receiver (menu-6-1-3 IIRC) check the address and band for the UHF remote and set your remote to use the same. Alternately while on the info screen, you can press the "record" button on the UHF remote to change the configuration of the receiver but be careful with that because if you have another receiver that this remote controls they will now both be listening to the same band/channel. |
#42 |
Helpful suggestion and I will try this once more.
However,......While more recent Bell/Dish Network remotes seem to have "A/B" switches to change UHF transmit frequencies, the older style silver remote supplied originally to us with the 5900 PVR does not seem UHF ch adjustable. Since this older silver remote already talks fine to the 9241 via infrared, I would assume it's address is the same as that at which the 9241 is watching for BOTH UHF and infrared signals. I still suspect the remote's UHF TX channel is different and am still looking for a hack to change it.........gotta be a way ???? No ? Yes ???? |
#43 |
There is no need to "hack" anything. Just simply change the Remote Address, an easy procedure that allows for 16 different codes.
Whilst on the System Info screen, as described above, MENU, 6, 1, 3. Press and hold the SAT button, all lights will flash. Let go of SAT button. Then enter the code you want, from 01 to 16. Press the # Button. If the code you entered is valid the SAT button will flash 3 times. |
#44 | |
The remote addresses between IR and UHF can and usually are different. |
#45 | |
| Tags |
| 9241, bell tv, belltv, hdcp, hdmi issue, ppv, pvr, recording |
