#76 |
I'm good now thanks for your help
#77 |
Another working EHD for the 6131.
I've got the following connected and working: WD My Passport 500GB drive non-powered. |
#78 |
I have been running the 6131 for couple weeks now, about once or twice a day the screen will just go black and say no signal, but then come back after a reset, Anyone else get this problem?
BELL tech says may have to be replaced. |
#79 | |
Seems to be working fine |
#80 |
The bell tech's showed up and installed my 6131 today.
She said ok lets hook up the HDMI cable and see if it works, we seem to have problems lately making it work and we might have to use the other methods. The cable worked but there is something wrong I think, or maybe not I have a sharp 32" lcd tv. the screen resolution is supposed to support 1366X768 which is 720. However the input on the HDMI says 480p. Does anyone have the same or similar configuration that could comment. Another issue is we used to have a 5900 and when we would record something it would default to once. Now with the 6131 it defaults to record every show. Is there some update I am missing. |
#81 |
A simple fix shub
Go into the receiver menu, and set the output to 720 I believe it is Press Menu then #6 then #8 Enjoy! With the record feature, you have to select how often you want it to record, and it seems you are selecting EVERY show When you select a show to record, go slow, and choose the appropriate option, once, weekly, New, every, etc... |
#82 |
Thanks, that works great
#83 |
I prefer using WD or Seagate drives personally. Have been using both (640GB successfully, no issues) with both external hard drive enclosure and USB docking station.
The Bell specs indicate that the drive MUST be powered externally. I would assume from that that they USB bus inside the receiver is not designed to power an external drive. |
#84 |
There is an ethernet port on the 6131 - does anyone know what functionality it provides, or is planned to provide?
Second question - is there any way to put the 6131 into "source direct" mode, i.e. to get it to pass programming through at whatever resolution it is received at rather than having to choose between 480, 720 or 1080? |
#85 | |
Bell broadcasts HD at 720p so setting your receiver to output at the same resolution will avoid any conversion issues. Use whichever scaler you find best, your receiver or your tv. |
#86 |
Wondering if anyone can help me out. Purchased a 6131 and had it activated. However, when I hooked an EHD up to it, it didn't recognize it. Called Bell, and asked if this feature had to be 'activated' by them (even though when I originally activated the receiver I was told that this feature did not need to be activated). The CSR told me that he was going to send down a 'booster' signal, give it 2 hours.
Well, still no luck, the 6131 will still not recognize my Comstar EHD (meets all the requirements). Am I missing something, or do I just have a defective receiver? FYI, I have formatted the EHD. Thanks! Forgot to add - all my programming is up and running, just doesn't see the EHD |
#87 |
Where did you format the drive? I would unplug the power & satellite from the receiver and try it again make sure you have V166 software on the receiver.
#88 |
Thanks Haystack! Yes, I tried resetting the receiver, unplugging it, etc., no luck. Software version is V166. The EHD was formatted using Linux......starting to think I may have got a bad receiver!
Perhaps I'll try phoning Bell again when I have a free 1/2 hour........ |
#89 |
I would clear the drive and let my receiver format it.
#90 |
Haystack, I'm not sure what you mean by clearing the drive - the EHD has been formatted, but when I plug it into the receiver, nothing happens - it's like the receiver doesn't even know it's there.
| Tags |
| 6131, 6141, extenders, pause, pvr, record, remote, signal, wireless |
