Use splitter instead of running third cable? - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Canadian Internet, Phone, TV and Wireless Service Providers > Shaw Direct (formerly Star Choice)
Old 2009-01-18, 01:23 PM   #1
btlsfan
Default Use splitter instead of running third cable?
Hi,
I have a new elliptical dish with a quad LNB (I think that's what its called?), and I have two lines going into the house from the dish. I have two receivers hooked up, but my brother is going to be living with me for a while (financial problems) and he said if he brings his receiver to my house and run a line from the dish to his, he will still get the programing. (he doesnt want to activate one of my old receivers on my account), but since there's 4 feet of frozen snow and ground - so I was wondering if there is any splitter that I can get that will work... I have a splitter from when radio shack was around it worked with old non elliptical dish back in the day but not the new elliptical and lnb... also should I stop my brother from bringing his receiver... in terms of legality?
btlsfan is offline
Old 2009-01-18, 01:28 PM   #2
tablo
Splitter will work (*I think*)if ur brother's reciever has smart card, and subscribed... Dish is just like antenna.
tablo is offline
Old 2009-01-18, 01:56 PM   #3
steelers2005
This is what i would do. His old reciever would not work unless it is activated. Just call *C to activate his rec ( Depending on pkg there is a 4.99 fee per month) and just hook it through a splitter. Radio shack will know the right splitter or by from *C. Your Bro's reciever would have to be under your name for him to bring it over. All he has to do is call to transfer it to you and vise versa when he leaves. Good luck.
steelers2005 is offline
Old 2009-01-18, 02:31 PM   #4
classicsat
It will not work. A coax has only one of four sets of transponders at a time.
If two receivers on a split coax ask for channels on a different set of transponders, one will not get the channel it is asking for.
You need to run a coax so that the added receiver gets independant choice of chanels.
classicsat is offline
Old 2009-01-18, 02:36 PM   #5
BGY11
classicsat is correct -- splitters will not work. Also, technically he shouldn't be bringing his receiver at all, as that is against the TOS (receiver should only be used at the place listed on the account -- or a Home Away From Home address, but that costs an extra $50 to set up).
BGY11 is online now
Old 2009-01-18, 05:27 PM   #6
btlsfan
Thanks for the quick responses guys.
@classicsat - you are correct I tried that and if I was on lets say 500 CNN and he tried 555 military... it would not work on the other (when using a spliter). I just bought a 150 ft spool of standard coax, so were gonna run that over the snow until it all melts and if hes still living with me we will bury it.
Does anyone know if the splitter starchoice sells will work? or is that ony for taking 4 from the dish in and 8 out?
Once again this forum has helped...thanks again.
btlsfan is offline
Old 2009-01-18, 05:56 PM   #7
QCK
As already stated, there is no single cable splitter for Star Choice.
QCK is offline
Old 2009-01-19, 03:23 AM   #8
dennism3
Yes 4 from the dish and 8 out is correct.
dennism3 is offline
Old 2009-01-27, 11:09 AM   #9
kcowan
Location: VancouverBC/PV Shaw Direct 505-530-630, Telus Landline, Rogers PayGo, Panasonic Viera 50", HTPC-HDMI
We just took an activated receiver and hooked it up to the second satellite in our Home Away. No extra fee. Since then, we have added 505s from craigslist problem.
The connection to the dish needs to communicate a 14v or 18v signal to select which satellite to receive.
kcowan is offline
