Started this thread so that people can report their findings rather than posting in various other threads...for the record, not getting any HD channels at this time myself....
"There was an issue on the spacecraft, and it went into safe mode," said John Flaherty, a spokesperson for Telesat, in an OBJ interview.
"It shut itself down and turned itself towards the sun. The solar arrays can keep the batteries charged, and nothing happens to the spacecraft. We've been in contact with the satellite and are in the process of essentially rebooting it."
I got this a bit earlier not sure how it well it will copy and paste
To accommodate customers and key events this evening (Montreal Canadiens vs. Toronto Maple Leafs and Les Auditions de Star Academie 2012), we have made five of our most popular channels accessible by alternate means. These channels will be available in the next few hours.
Available channels:
NAME
CHANNEL NUMBER
(Classic/Advanced)
CBC HD
292/300
RDS
750/750
RDS HD
240/382
TVA HD
245/381
TVA Montreal
711/711
RDI on channel 730 and Teletoon French on 771 are unaffected by this outage.
I'm sure in the worste case senario, they could lease another spare satellite and move it to the 111 orbital location. This isn't the first time a major satellite has failed. The only issue might be that a spare satellite probably would not have enough power to supply the same amount of transponders.
Self serve on the web site is down as well. The channel remapping has messed up the subscription info and I want to do a receiver refresh. It's a no-go on that. What a mess.
CBC HD is 300 on the advanced line-up. If you have the classic line-up, tune to CBC HD. I'm getting the Leafs-Habs game in HD on CBC and RDS. The rest of the HD channels are still out (have have been substituted with their standard-def version).
I'm still getting it in HD. I'm not sure exactly time time it started, but it was around the time of puck drop. Lucky me I guess. Maybe try a receiver refresh.
If this minor solar flair was the cause of the satalite failure, Wow telesat is in big trouble. we have had much stronger in the last month or two.
I follow the suns activity and aside from a respectable sunspot number of over 100 it is relatively quiet in the last few days and is unlikely the cause of the problem.
the CME (Corronal Mass Ejection) that was released by the comet diving into the sun was part of the cause of this minor storm but other solar flairs contributed as well.
If the actual solar flair hit the satellite, TV would be the least of our problems. rather than the flair itself its the result of a solar flair can hit a satellite and knock it out. the Gama/xray burst is the first damaging effect of a solar flair. this is a huge concern to those in space. this happens minutes after the actual flair.
The next event caused by a solar flair that can cause problems is the arrival of the plasma and sun matter released by the solar flair called a CME (Coronal Mass Ejection). This is usually a few days later. and is a major concern to satellites as his can knock out satellites and other space craft directly
Then the next worry is the geomagnetic storm that the arrival of a CME can set off. this is what causes most auroras and is what blacked out Quebec many years ago and in the 1859 superstorm severely damaged the telegraph system causing the lines and apparatus to burn melt and catch fire. If one of those hit us today we would be in it deep
The geomagnetic storm set off by the recent solar flair was mild. it set off some auroras in the polar regions to the delight of some photographers but had little effect otherwise.
The K index which is the measure of the magnetic storm maxed out at 5. and by no means a storm but merely minor disturbance. we have had much stronger in the last few months. we are only in the beginning of the current solar cycle so many more flairs to come. satellites are designed to handle solar flairs, and the resulting CME and storms and will withstand a solar flair and earth directed CME of multitudes stronger than the minor disturbance that we just had.
I would think channel maps are probably getting really messed up right now.
dmoes, that's some good info. Thanks!
Related Threads
1.7M posts
114.9K members
Since 2001
A forum community dedicated to Canadian TV, computing and home theatre owners and enthusiasts. Come join the discussion about home audio/video, displays, troubleshooting, styles, projects, DIY’s, product reviews, accessories, classifieds, and more!
