I bought a denon avr-588 about a month and a half ago, and while up until today had no problems with it. However when I turned it on today, it didnt work (it had been working properly last night).
Basically what it is doing now is when the power switch is on, it goes to standby mode, and there is a red light that stays on constantly. Normally when I hit the power putton, it switches to green, and everything works fine.
But now when I hit the power button, it goes to green for about 3 seconds, and appears to work fine, but then suddenly the light just begins to flash red, and nothing works.
I checked the manual for my reciever, and it had listed this as one of the problems in its troubleshooting guide, but the only solution it offered for this problem was to make sure the power cable was connected properly. It seemed fine, but still didnt work, and as of now I have tried plugging it in to a different outlet on my surge protector (everything else connected to the surge prottector is working fine), I tried unplugging everything else and trying the reciever, I tried a different surge protector, and tried pluging it directly into the wall, and tried a completely different outlet. But I still get the same result.
Is there anything else I can try?
