I asked KVOS Bellingham's general manager and engineering staff about their progress towards DTV (they're running DTV on UHF 35 remapped to 12.1 in a lab bench sort of system for now) and received this reply:
Dear Jon,
KVOS is only able to operate in DT with a low power (1KW) transmitter
from Bellingham at the present time. Though some people in White Rock
may be able to receive our signal, I doubt that you would be able to
receive our signal in Delta on Ch.35 based on the location of our
antenna and the low power.
We hope to have our new transmitter and more importantly, our new
antenna operational by mid-Summer '06. With that new transmitter, we
will be providing a robust signal from the top of Mt. Constitution on
Channel 35. (We have not been able to make the full transition due to
tower location difficulties. We hope to have a new tower build by the
end of next Spring--but regulatory officials still have to grant
approvals for us to build the tower.)
We will eventually migrate back to Channel 12 DT once the cut off period
has been declared by the FCC sometime after 2006.
Should you have any further questions, I encourage you to contact John
Franz, our Chief Engineer.
I'm showing KBTC-HD on 28.1 and MHz Wld on 28.2. My signal strength meter is showing 94% and I see good audio and video. I have some dinosaur kids show in HD on 28.1 and Chinese news in SD on 28.2.
Signal update for 24.1 and 24.2 there is a problem with the amp unit and it is actually only using about 10% power right now and in a week or so that will be replaced which means a lot more signal and quality.
Oh man you are making me semi-hopeful I'll be able to get PBS in False Creek when the power goes up. My fingers and toes are crossed but I don't know if I can keep them crossed for a whole week!
The bedroom tv (Sony KDL46XBR) won't find 28.1....it found 24.2 (World News)
24.1 Shopping, but no 28. This is the same tuner that won't remap CBUT
(58.8) to 2.1. New and improved Sony junk.
That contour a few posts back post #324, still is a nice contour and it would be ashamed not to add another 1080i station it seems to me there is still room
Mght be best to scan near summers end and perhaps we'll have another station
Why summer's end? Just a guess? That contour was a best guess from Stampeder re the K60GV-D application. From what I can tell, there is an LD station NE of Everett/ accompanied by a translator on Orcas for that station related to that application, a digital flash cut approved as of April 26, 2010, expiring end of March, 2011. I'd hazard a guess that it could happen anytime, although Stampeder is probably best suited to decipher all those applications!
From Queensborough area, both channels are quite clear and I have a signal strength of about 55 -60 percent using a GH6 antenna, which is still in the living room
Thanks for the call. The translator on Mt. Constitution actually gets KBTC’s signal off the air. We have a UHF receiving antenna 150 feet up the tower that picks up KBTC-DT’s digital transport stream on channel 27, then what we do is run that digital transport stream into the channel 24 transmitter and re-broadcast it. 99% of the time this works very well because we get great signal up there.
You saw break-ups last night because the windstorm was blowing around the UHF antenna on the tower and disrupting the OTA reception of KBTC’s main digital signal on channel 27at the transmitter site. Normally this isn’t a problem; windstorms like we saw last night are not a frequent event. Although we are looking at the possibility of getting a fiber feed of KBTC’s transport stream to the transmitter and that would provide stable signal even during a windstorm.
KBCB is off the air because the windstorm knocked out power to the transmitter site. The PBS translator is still on the air because there is a small back-up generator at the transmitter site. The generator is big enough to keep the 200 watt LPTV signal on the air, but it can’t handle keeping the 5kW KBCB signal on the air.
P.S. Thanks for letting me know yesterday about the status of CBUT’s signal.
KVOS-DT has been down for me in New West for 2 days now. Anybody else having the same issue ? (the shopping channel is down as well, but who cares about that )
Anyone with an interior antenna managed to pick up K24IC-D? I've moved mine all around the house, and found a position where I will pick up KBCB 19.1 at 80% and KVOS-DT 35.1 at 100% on my Samsung TV (strongest it's ever been), but still no luck with K24IC-D.
Related Threads
1.7M posts
115K members
Since 2001
A forum community dedicated to Canadian TV, computing and home theatre owners and enthusiasts. Come join the discussion about home audio/video, displays, troubleshooting, styles, projects, DIY’s, product reviews, accessories, classifieds, and more!
